Total wood working noob here with a question
Forum topic by 12secondnova posted 10-19-2016 01:44 PM 723 views 0 times favorited 13 replies Add to Favorites Watch
View 12secondnova's profile
12secondnova
1 post in 824 days
10-19-2016 01:44 PM
Hi everyone. I’m not even sure if this is the right forum to put this question in thats how little I know about this stuff. So if this is the wrong place please delete.
I have a 1970 chevy pickup with a wood bed that is completely rotted out gone and I will be replacing it soon with either a pine or oak kit. My question is can either of these types of wood be finished with a stain or something that will give it a kind of RED tint to it? My truck is white with red interior and I think the inside of the bed mirroring a white over the red theme would look cool. Its not going to see hard work like throwing rocks in it(it might haul a motor or two but I plan on having a rubber mat over it IF that ever happens) BUT it will be parked outside in direct sunlight most of the time, So I would be nice if its a durable finish so I don’t have to refinish it very often. Any help is appreciated! Thanks, Chris
13 replies so far
View WhyMe's profile
WhyMe
1080 posts in 1800 days
#1 posted 10-19-2016 01:58 PM
Oak is a better choice for durability and it can be stained with a red toned stain. Oak is a hardwood where pine is a softwood.
View Bill White's profile
Bill White
5149 posts in 4199 days
#2 posted 10-19-2016 02:00 PM
Outside, sun, stain finish??? Ain’t gonna last too long. You certainly can stain wood to whatever color ya might want, but the conditions are just not going to allow long term success. Probably have to refinish or touch up the top coat pretty often.
I would suggest that oak (white oak to be exact) would be the best wood choice.
Welcome to LJs.
Bill
-- bill@magraphics.us
View HokieKen's profile
HokieKen
7584 posts in 1378 days
#3 posted 10-19-2016 02:02 PM
- WhyMe
+1. I’ll also add that oak is naturally decay resistant (at least moreso than most woods). Cedar may also be a good choice. It’s decay-resistant and is naturally red. It is soft though.
-- Kenny, SW VA, Go Hokies!!!
View nkawtg's profile
nkawtg
281 posts in 1490 days
#4 posted 10-19-2016 02:07 PM
+1 to all of that, and stay away from Pine.
View rwe2156's profile
rwe2156
3232 posts in 1720 days
#5 posted 10-19-2016 02:11 PM
Oak. Pine & Cedar too soft.
You can use a color dye to tint the wood prior to finishing.
If outside all the time, don’t expect any finish on a horizontal surface to last long. UV light and severe weather changes are the issue.
I would probably be taking a look at at an epoxy.
WhyMe
#6 posted 10-19-2016 03:06 PM
White oak is the best of the oaks to use. After staining use a finish coat of marine spar varnish.
View Madmark2's profile
Madmark2
409 posts in 827 days
#7 posted 10-19-2016 03:14 PM
Redwood won’t rot and has a natural red finish. Several coats of a UV protected polyurethane are in order before installing.
M
Smitty_Cabinetshop
15820 posts in 2857 days
#8 posted 10-19-2016 03:19 PM
+4 or +5 to white oak as the better option, and yes it can take a red stain easily. For durability comments, I’ll echo RWE’s sentiments.
View Woodknack's profile
Woodknack
12465 posts in 2619 days
#9 posted 10-19-2016 04:41 PM
Use padauk. It’s red, rot resistant, harder than oak, and not very expensive.
View Kirk650's profile
Kirk650
585 posts in 987 days
#10 posted 10-19-2016 05:28 PM
If you use Oak, do not use Red Oak. Use White Oak.
MrUnix
7107 posts in 2438 days
#11 posted 10-19-2016 05:43 PM
I have no idea what was used in later models (70’s), but I had a ‘52 Chevy long bed pickup that I replaced the wood on many years ago. According to Chevy and several other sources, the wood used originally on the truck was Southern Yellow Pine. Early models were treated with linseed oil and lampblack, while later year models got painted to match the color of the vehicle. I used SYP and treated with a water sealer… I guess it could have been stained any color first, but I just left it natural.
PS: The truck was never garaged… it sat out in the hot Florida sun 24×7x365. I sold the truck a few years after replacing the wood, but have seen it since (almost 20 years after I sold it). The guy never did restore it like he said he was going to do, and it’s sat in his back yard for years and now has a tree growing through it! But the wood, while obviously has taken on an weathered look, is still holding up great despite it’s mistreatment.
View splintergroup's profile
splintergroup
2511 posts in 1461 days
#12 posted 10-19-2016 06:30 PM
Since you mention a “kit” I assume that you don’t plan on cutting the wood yourself. In that case, the best of the two would be Oak, stained with whatever color you like.
Cutting your own wood really opens up options. It sounds like you plan on protecting the wood from mechanical damage and this makes softwoods a reasonable alternative. Redwood will handle the weathering better than most stuff and the color is built in 8^). Exotics like padauk or jatoba will also serve nicely and are available for not much money.
splintergroup
#13 posted 10-19-2016 06:42 PM
Sorry! double post.
