Cleaning glue bottle tip
« back to Joinery forum
Forum topic by thor2015 posted 10-19-2016 02:50 AM 769 views 0 times favorited 12 replies Add to Favorites Watch
View thor2015's profile
thor2015
42 posts in 1293 days
10-19-2016 02:50 AM
I was just curious if anyone else here cleans out their glue bottle tips after being done with them for the day. I know that the cap is supposed to seal after it is pushed closed and keep the glue inside from drying out but I wasn’t sure if the glue at the very tip would dry and cause opening/dispensing problems.
12 replies so far
View DirtyMike's profile
DirtyMike
637 posts in 953 days
#1 posted 10-19-2016 02:56 AM
The tip will easily pull off on most bottles, run it under hot water and use your diresta ice pick to remove any nasty nate.
View Lazyman's profile (online now)
Lazyman
2162 posts in 1438 days
#2 posted 10-19-2016 03:23 AM
I sometimes store it upside down, closed of course, so no glue dries in the tip but as long as you don’t forget to cap or close it, it’s not much of s problem anyway. PVA wood glue doesn’t stick very well to plastic, so it is pretty easy to peel it out of the tip if you do get some dried glue in there.
thor2015
#3 posted 10-19-2016 04:07 AM
Thanks! I already unscrew the cap and separate the two parts and run them under water using a brush to get into the narrower space at the top, but I just was not sure if this was considered overkill.
View Woodknack's profile
Woodknack
12014 posts in 2431 days
#4 posted 10-19-2016 04:12 AM
I used to break Titebond bottles all the time because the tips are the worst. I switched to a French’s mustard bottle and all is well with the universe. I might switch to a Heinz mustard bottle because the cap snaps back out of the way whereas I have to hold the French’s cap with a finger while I squeeze out glue.
View mike02130's profile
mike02130
167 posts in 724 days
#5 posted 10-19-2016 11:43 AM
I used to use my teeth to pull off the dried glue from the tip. It made for good chewing. Now that I have no teeth, I use my fingernail. I’m just not that anal.
-- Google first, search forums second, ask questions later.
View bbrown's profile
bbrown
230 posts in 3603 days
#6 posted 10-19-2016 12:38 PM
For cyanoacrylate (superglue) a little vaseline or mineral oil on the tip does the trick…..
http://www.woodworkersjournal.com/keep-glue-caps-sticking/
-- Bill Micah 6:8
View rwe2156's profile
rwe2156
2997 posts in 1532 days
#7 posted 10-19-2016 02:13 PM
I used to use my teeth to pull off the dried glue from the tip. It made for good chewing. Now that I have no teeth, I use my fingernail. I m just not that anal.
- mike02130
View Kirk650's profile
Kirk650
525 posts in 799 days
#8 posted 10-19-2016 05:30 PM
Teeth. That’s what I use. Fast, easy, effective.
View Dano46's profile
Dano46
82 posts in 3220 days
#9 posted 10-19-2016 06:24 PM
“Lazyman” has the right idea. Clean it everytime.
-- You can't trust a dog to guard your food.
View Ron Aylor's profile
Ron Aylor
2649 posts in 698 days
#10 posted 10-19-2016 06:50 PM
Tip? What tip?
thor2015
#11 posted 10-20-2016 11:41 PM
Sorry I’ve been away for awhile. Thanks for all the replies- you guys crack me up sometimes but I appreciate the helpful responses!
Ron, not all of us have a seasoned workbench like yours but I’m aspiring to get there. Looks like you have a good idea with the old candle jar.
View Dwain's profile
Dwain
545 posts in 3910 days
#12 posted 10-20-2016 11:46 PM
I do clean my tightbond glue bottle tips occasionally. I’ll let it sit in hot water for 10 minutes or so, then grab a bent paperclip and clean it up. Always works fine.
Oh, and Mike02310, I don’t mind that you chew your dried clue but I would worry if it gets down… there. You said you weren’t that anal. I certainly hope not.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
