Parallel clamp hack
Forum topic by TheTurtleCarpenter posted 10-18-2016 05:20 PM 1004 views 0 times favorited 7 replies Add to Favorites Watch
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1052 posts in 1214 days
10-18-2016 05:20 PM
Topic tags/keywords: jig clamp carving shaping finishing sanding sharpening woodburning joining
I needed a different clamping method and this setup was simple and could be used in a lot of different angles. I took the rear screw and threaded pins and reversed it to keep both handles at the top and out of the way. The 8 sided post is 8” long and I drilled a 1/2” hole thru the center for the front screw to go thru. Instead of screwing the post to the clamp I made a mortice a little oversize and used some leather and a clamp so it could be broke down and stored easily. Easy and inexpensive when you need something rotated and at a taller height.
All the Best, jd
-- "Tying shoelaces was way harder than learning to Whistle"
7 replies so far
View theoldfart's profile
theoldfart
10048 posts in 2599 days
#1 posted 10-18-2016 07:09 PM
Your a pretty clever young fella Turtle. Nicely done.
PS, got the same lamp setup on my bench.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
TheTurtleCarpenter
#2 posted 10-18-2016 07:52 PM
Kevin, I have glasses, a magnifier and I still have a hard time with anything under quarter inch. Ive been thinking of fitting that lamp up with LED’s for a little more brightness. Sometimes I put my contacts in and wear my prescription glasses on too. I used to read my tape in 32nds. ;>}
View robscastle's profile
robscastle
5314 posts in 2352 days
#3 posted 10-20-2016 10:05 AM
I couldnt get by without my “Maggy” lamp!!
Same as turtle Glasses hand held magnifing glass and now I find the marking om my steel rules have shrunk too.
Oh well I have had a good run, a braille rule will be next or if I get an injury it will be all over red rover WW wise
-- Regards Rob
TheTurtleCarpenter
#4 posted 10-21-2016 12:21 AM
I think my wife has been putting something in my food to effect my eyesight because now I cant tell a pretty girl from a sweet potatoe
theoldfart
#5 posted 10-21-2016 12:23 AM
That rules out politics then :-)
TheTurtleCarpenter
#6 posted 10-21-2016 12:57 AM
Kev, to go there you have to be blind and deaf. <(~)>
theoldfart
#7 posted 10-21-2016 01:41 AM
