Heat warnings 40c = 104f
« back to Coffee Lounge forum
Forum topic by GMman posted 07-06-2010 02:29 PM 1334 views 0 times favorited 16 replies Add to Favorites Watch
View GMman's profile
GMman
3902 posts in 3604 days
07-06-2010 02:29 PM
Topic tags/keywords: resource
Heat warnings continue across Ontario, Quebec
06/07/2010 8:03:59 AM
CTV.ca News Staff
Keeping cool will be the order of the day Tuesday—and for much of the week—as most of Central Canada and northeastern U.S. roasts in a heat wave.
A southern flow of hot air from the south—called the Bermuda High—has blanketed the area and is acting like a heat pump, moving warm, southerly air from the Gulf of Mexico northward.
The heat and humidity isn’t expected to break until at least Friday, when a cold front is forecast to sweep in and drop temperatures closer to seasonal norms of about 25 or 26 Celsius.
Environment Canada senior climatologist Dave Phillips says if it feels like this heat wave is hitting us hard, it’s because it’s been so long since we’ve had a long, withering bout of the three H’s: heat, humidity and haze.
“This is the first heat wave in, I think, three years for this area and that’s why it’s sort of noteworthy… And the humidity is so high, probably because of all that precipitation we had in June,” he told CTV’s Canada AM Tuesday morning.
Phillips notes that while we’ve already seen a few very hot days across Canada this summer, it’s the humidity element that makes the heat so dangerous.
“In this kind of heat wave we have now, when you add in that humidity factor, the air is just saturated with moisture and the body just can’t perspire. So we often see health problems associated with that,” he said.
Once again today, Environment Canada has issued smog and humidex advisories for parts of Ontario and Quebec. Humidex values are expected to be in the 40-degree range. The advisory covers southern Ontario and southern Quebec, from Windsor, to Montreal and the St. Lawrence River.
Many affected cities have opened special cooling centres and are urging people to use them. Those most at risk of heat stroke, such as young children, seniors, and those on certain medications, should try to spend the day in air-conditioned facilities, such as shopping malls, libraries and community centres.
For those whose jobs depend on being outside, Dr. Lillian Wong of the Ontario Ministry of Labour recommends taking frequent breaks, drinking plenty of water and staying in shady areas when possible.
The heat wave has already claimed the life of a homeless woman in suburban Detroit on Sunday.
With so many residents expected to crank up the air conditioning today, power utilities across Ontario, Quebec and in parts of the eastern U.S. are preparing for maximum demand, trying to avoid the blackout that hit a large swath of Toronto on Monday, leaving tens of thousands of people without power.
16 replies so far
View stefang's profile
stefang
15784 posts in 3241 days
#1 posted 07-06-2010 02:55 PM
Glad I’m here and not there. A heat wave here is 30c
View hairy's profile
hairy
2607 posts in 3439 days
#2 posted 07-06-2010 03:06 PM
I’m usually the oddball, and this time it’s no different. Ever since my military service, I prefer heat to cold anyday. Every place they sent me was hot climate, and I just got used to it.
These are the days I was hoping for last winter. Bring it.
-- My reality check bounced...
View HorizontalMike's profile
HorizontalMike
7747 posts in 2821 days
#3 posted 07-06-2010 03:27 PM
To ya’ll up there in Canada, ”Welcome to Texas” ;-)
View Jim Bertelson's profile
Jim Bertelson
4150 posts in 3071 days
#4 posted 07-06-2010 04:00 PM
A heat wave here would be 26 deg and above, and I don’t like it. However in Hawaii, I can handle the heat much better. In the middle east last year it was 38 degrees and more frequently. I did all right but I didn’t like that either. Good luck with your heat…......12.8 C, 55 F here, at 0600hrs.
Alaska Jim
-- Jim, Anchorage Alaska
View Cozmo35's profile
Cozmo35
2200 posts in 2943 days
#5 posted 07-06-2010 05:25 PM
26 Celsius = 78.8 Fahrenheit. I Googled it so it may be wrong. If it is actually 78.8 Fahrenheit…Ya’ll are doing GREAT!
-- If you don't work, you don't eat!.....Garland, TX
Jim Bertelson
#6 posted 07-06-2010 05:41 PM
Yes, that is correct. As soon as it gets near the 80’s F, we get uncomfortable here. I found I was doing conversions all the time, so finally I made a chart of Farenheit vs Centigrade.
Alaska Jim
GMman
#7 posted 07-06-2010 08:15 PM
View knotscott's profile
knotscott
7875 posts in 3283 days
#8 posted 07-06-2010 11:41 PM
This heat wave sucks….it’s so incredibly oppressive. I’m not particularly fond of cold weather, but it’s a lot easier to deal with than the 94°F with high humidity that we’ve been seeing.
....just waiting for it to end!
View NBeener's profile
NBeener
4816 posts in 3081 days
#9 posted 07-06-2010 11:52 PM
knotscott: I’m with you, Buddy. I’m in New England … “enjoying” the record-setting heat wave.
Blecch.
Y’all who like it … can have it :-)
-- -- Neil
View richgreer's profile
richgreer
4541 posts in 2981 days
#10 posted 07-07-2010 04:35 AM
We are not suffering from excessive heat in the midwest (Iowa) but we are into our 3rd year of screwy weather. Abnormally cold winters and abnormally wet summers. I have a very good in ground sprinkler system. For many years I used it a lot every summer. This is the third summer that I have not turned it on (so far).
View Rick's profile
Rick
8904 posts in 2940 days
#11 posted 07-07-2010 09:51 AM
UPDATE:
From Gov’t Of Canada Weather Site …At 3:44 AM Wednesday the 7th. Toronto Area.
Expected High of 33 Celcius (91.4 F). .....UV Index Warning 10 VERY High. ....Humidex Advisory Warning at 60% To “Top” that all off a …...High Smog Alert Warning in affect.
No wonder all that Nice Snow Melted.
-- Real MEN! Measure Once! Cut Once! Then head back to the Lumberyard. (Rick, Ontario, Canada)
View littlecope's profile
littlecope
3071 posts in 3409 days
#12 posted 07-07-2010 11:27 AM
We flirted with a 100° all afternoon yesterday here…
Usually it doesn’t bother me that much, but this year it’s tough…
Of course, I picked yesterday to do the folk’s lawn!!
I tried to do it early, to escape the mid-day heat, but it was 97° by the time I finished… Air so thick, you can cut out blocks and stack them…
I’ll take the Winter cold anytime!!
View JimDaddyO's profile
JimDaddyO
533 posts in 2986 days
#13 posted 07-07-2010 12:49 PM
40° C just north of London ON with the humidity, not getting much done, but the air condititioner is working hard.
-- my blog: http://watertoneworkshop.blogspot.ca/ my You Tube channel: https://www.youtube.com/channel/UCA5AretE3xPoVDV61AxUdUA?view_as=subscriber
View MarcusM's profile
MarcusM
57 posts in 2887 days
#14 posted 07-07-2010 01:03 PM
I can relate JimDaddyO; I’m a little southwest of you. This is the first time in a good 20 yrs I wish I had an air-conditioned shop…probably a mix of the heat and my getting older :).
Mark.
-- Tilbilly Mark
GMman
#15 posted 07-07-2010 01:30 PM
Well nice weather to dry my fire wood for next winter we get 40F below here.
