Mask for turning
« back to Woodturning forum
Forum topic by loiblb posted 10-18-2016 09:48 AM 560 views 0 times favorited 3 replies Add to Favorites Watch
View loiblb's profile
loiblb
142 posts in 1081 days
10-18-2016 09:48 AM
Mask for turning pens using CA glue.
I use a cartridge dust mask for turning. I notice my eyes have reacted to using CA glue. I have to use something other than CA or a better mask.
3 replies so far
View Wildwood's profile
Wildwood
2322 posts in 2160 days
#1 posted 10-19-2016 10:22 AM
Unless you use a full face respirator, or use a fan to blow fumes away from you not sure what you can do.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=packard&Category_Code=hlth-sfty-proair
I became sensitized to CA so stopped using it to finish pens. Switched to oil or water poly and lacquer as a finish. These days still use CA as a crack filler but not very often.
-- Bill
loiblb
#2 posted 10-20-2016 02:18 PM
I found out on Pen turners about odorless CA will not do the stuff reg. CA does to your eyes and lungs.
https://www.amazon.com/Super-gold-thin-odorless-Bob-Smith/dp/B0000DD1QJ/ref=pd_sim_229_3?_encoding=UTF8&psc=1&refRID=WD11W47N8V42AWGZT3NC
View DrDirt's profile
DrDirt
4424 posts in 3767 days
#3 posted 10-20-2016 02:53 PM
I found the ventilation was key – have a “snorkel” dust collector behind the piece and it draws away the fumes – so i have not had this issue of either smell nor eyes burning
I find it ‘mediocre at best for catching chips… as they have more inertia as they fly out of the “jetstream”
But for sanding dust and fumes – - it works well
essentially this
