Profile advice needed
Forum topic by romanweel posted 10-17-2016 10:48 PM 711 views 0 times favorited 10 replies Add to Favorites Watch
View romanweel's profile
romanweel
17 posts in 1392 days
10-17-2016 10:48 PM
Topic tags/keywords: advice router profile
Hey y’all,
I’m trying to match this profile and looking for a router bit or bit combination that will get me in the ballpark. I don’t mind building it up with a few different cuts, but I’ve only got a small ogee bit that looks like it’ll get the top and nothing that comes close for the bottom. Any suggestions? I’d even take a second-hand moulding handplane if the shape were close enough, but I’ve been striking out here.
10 replies so far
View JBrow's profile
JBrow
1366 posts in 1066 days
#1 posted 10-19-2016 12:44 AM
romanweel,
A perfect match to the moulding could be obtained with a custom made cutter in a moulding machine.
If the moulding does not need to be an exact match to the sample moulding, then perhaps you could find a close enough profile from the catalog of a router bit vendor. I took a quick look at the MLCS web site and discovered that they offer an impressive array of moulding router bits. After opening the link, scroll down to the category MOLDING.
http://www.mlcswoodworking.com/shopsitesc/store/html/smarthtml/pages/routerbit.html#moldinganchor
There may be a set of router bits that together could achieve the profile, but I am not sure what that combination would be.
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1052 posts in 1211 days
#2 posted 10-19-2016 01:37 AM
That looks like an older base cap profile and they vary slightly in shapes and length and widths. Depending on how much footage you need you can make it yourself or have or have a millwork supplier cut knives and run it for you. Very often you can find a close match on Ebay or you can make a template and cut down most of the waste and make a metal scratch stock out of metal and finish scraping further down to the finish profile. On ebay, you can do a search for complex moulding planes. http://www.ebay.com/itm/Complex-Molding-Plane-Moulding-/361321959857?hash=item54207791b1:g:6ecAAOSwstxVfzci
-- "Tying shoelaces was way harder than learning to Whistle"
View sras's profile
sras
4883 posts in 3275 days
#3 posted 10-19-2016 02:43 AM
If you’re willing to do a little hand touch-up, you could form the bottom feature with a couple passes on a table saw set at 45 degrees. A few passes with a plan would round off the edges and then use the ogee bit.
View Lazyman's profile
Lazyman
2526 posts in 1533 days
#4 posted 10-19-2016 04:11 AM
The closest examples I could find were usually called base mounding so you might check some online mounding catalogs for examples that are close enough.
How long a piece do you need? If you just need a short piece, you can try cutting the negative profile as a sanding block on a band saw and attach some sand paper to it to shape another piece by roughing it out on table saw and router table to get it close and then sanding to the final profile. Here is where I got that idea:
https://www.thisoldhouse.com/how-to/how-to-duplicate-custom-molding
View mike02130's profile
mike02130
170 posts in 818 days
#5 posted 10-19-2016 12:06 PM
Being that I’m a finish carpenter in Boston, I often have to replicate old mouldings. Trace the profile on the end of an oversized piece of wood. Then draw straight square lines over the profile as if you were going to cut a series of rabbets. Sit down and study it and make a plan of attack. Use a table saw, maybe a router bit or two and a small shoulder or rabbet plane to shape. If you can find a similar moulding that is slightly larger, you can shape that.
If you go that route, use a board wider than your moulding so you have a surface for your router and table saw to ride on. You may find it easier if you make it a two piece moulding. Rip it at the 5/8” mark in your picture.
Forget the moulding planes on eBay. You would be taking a guess, most people selling the planes don’t have enough sense to show the profile. You’ll just end up frustrated and upset.
If you had a cutter made it would probably run you a couple hundred bucks.
I just made a similar moulding in a 3’ and 6’ length. It took three hours and I charged $180.
-- Google first, search forums second, ask questions later.
View Carbide's profile
Carbide
210 posts in 2592 days
#6 posted 10-19-2016 03:06 PM
I had the same problem while remodeling an old house. I could not find a match for the base cap. So i made new moulding with a new profile and replaced all of the base cap. I feel that it took me less time to make new than messing around for hours trying to match the old. But if you choose to try to match the old then try here http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_multi.html
I own this bit and have used it several times for moulding profiles.
-- When it feels like a job, it isn't a hobby anymore.
romanweel
#7 posted 10-19-2016 07:34 PM
Thanks, everybody. Yes, it is base cap from an old house, and I would much rather replicate it than replace it, even if it takes a while of fussing. I’m going to keep watching the planes on ebay, but none of the ones there at the moment look quite right, and in the meantime I’ll work on my table saw/router table plan of attack (no band saw…yet). I dunno why I keep looking for quick fixes…three or four hours of my time versus a new not-quite-right router bit and a wad of cash? The process should be interesting, anyway.
TheTurtleCarpenter
#8 posted 10-19-2016 07:48 PM
I think the tablesaw is your best resource Roman. Take a cardscraper or something a little thicker and cut the profile in it a fasten it into a block of wood to finish it out and, fastening it in a block will give you a register to control depth. Good Luck
Lazyman
#9 posted 10-19-2016 07:59 PM
Again, this might depend upon how long of a piece you need and I have never tried this but you might be able to use a fret saw and some sheet metal to fashion a sort of scraper. Trace the profile on the metal and cut it out with a fret saw and use a file to refine the profile. You want a smooth and continuous edge. If you can get a burr on the edge like a standard card scraper, it will cut better. You’ll want to get as close as you can with table saw and router before using the scraper to minimize the amount of scraping.
Just an idea.
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15575 posts in 2764 days
#10 posted 10-19-2016 09:24 PM
How many linear feet of this profile do you need? Hollows and rounds can do it. Another solution is to raid base cap from a smaller area to get what you need (closet that was framed in, maybe) and replace it with near-match stuff.
