Power Switch
Forum topic by Hutch posted 323 days ago 798 views 0 times favorited 10 replies Add to Favorites
View Hutch's profile
Hutch
57 posts in 425 days
323 days ago
I’ve been working on improving my table saw with a new fence. Now to the next safety upgrade. I want to mount a new switch for my table saw and my router table (right wing). Should I look for a magnetic switch so that if the power is interrupted the saw/router will not come back on when the power is restored? I would like to mount a faceplate in front of the switch which requires me to reach through a hole to hit the on button and have the faceplate extend down about a foot so that I can bump it with my knee to shut it off.
Any comments or suggestions, as always, are greatly appreciated.
-- Hutch, Montana
View Sawdust2's profile
Sawdust2
868 posts in 616 days
323 days ago
It’s a matter of choice as to how you do this.
For me it was sufficient to just relocate the switch from the base of the saw to the edge of the Xacta fence.
I just bent a piece of metal and took the switch form the saw, attached it to the metal and it was a LOT easier to reach. My concern was not turning it on but being able to quickly shut it off.
View Peter O's profile
Peter O
669 posts in 403 days
323 days ago
I like the idea of the magnetic drop-out switches that won’t come back on when power is restored, but if the lights are out, how likely is it that you’re going to pick that time to fiddle with your blades? I have the mag switches on my table saw, band saw, and jointer.
I like the knee bump to shut down. Sometimes you realize that things aren’t right, but if you let go with one hand things will get worse!
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
View motthunter's profile
motthunter
1229 posts in 327 days
323 days ago
i like a magnetic switch and I also love a huge knee bump shut off. Safety first
-- making sawdust....
View rikkor's profile (online now)
rikkor
8365 posts in 403 days
323 days ago
How often does the power go off? I’ve only lost power once in thirteen years at this location, and I wasn’t in the shop at the time. You may have enough safeguards in place already.
-- Maplewood, MN
View Blake's profile
Blake
2206 posts in 403 days
322 days ago
There are many ways of doing this off the shelf or home made. But you’re on the right track. Just decide if you want a foot kick switch (for hands free shut-off) or if a hand paddle would be adequate.
-- Check out my new website! http://www.theeasellife.com
View Woodchuck1957's profile
Woodchuck1957
159 posts in 292 days
288 days ago
The power switch I had on my Delta 34-445X Contractors saw was a toggle switch mounted low on the cabinet. I wanted a paddle switch undernieth the fence rail on the left side to get to it easier, plus I never did like the switch box inside the cabinet filling up with dust. One of my first concerns when relocating the switch was would the wireing to the motor be long enough. It turned out not to be a problem. So this is how I started. I bought a paddle switch from Woodworkers supply, it’s a Woodtek brand that comes with a plastic box to mount it in. I modified the new box to accept the Delta wireing useing the old Delta metal box as a marking template for the slots. Delta metal box New box modified Wires inserted Wires ready Next I needed to design and build a switch mount for under the fence. Switch mount The switch mount is actually mounted with one bolt undernieth the extension wing where the fence bolts to it. I wanted it set the switch back some so the chances of accidentally bumping into the paddle and shuting the saw off during a cut would be reduced. Installed Ready I’m very pleased with the way the project came out, the switch is mounted firmly and now I don’t have to reach way down and try to find a tiny toggle switch anymore. This upgrade was long overdue, and well worth the time and what little money it cost. It should easily pay for itself quickly in safety.
-- If you can't find the time to do it properly, how will you find the time to fix it ?
Woodchuck1957
283 days ago
Once again, why do I bother takeing the time to post these prodjects ?
Peter O
283 days ago
Woodchuck, it looks like you have some great ideas for solutions to a common problem.
I think when you reply to someone else’s post, other LJs assume you are giving feedback instead of looking for feedback. If you want ideas or opinions about what you’ve done, you might start a new forum topic.
View Dadoo's profile
Dadoo
1549 posts in 519 days
282 days ago
Actually I think that all large shop tools should come with a magnetic type switch. It’s just another one of those safety issues that should be.
View Mark E.'s profile
Mark E.
67 posts in 271 days
270 days ago
Here is a not so good picture of the knee kick cut off switch I made for my Grizzly 1023. It is made from standard 3/4” PVC pipe and fittings. The idea came from a woodworking magazine, but I can’t remember which one.
Safety knee kick
-- Mark
Bookmark And Share This Page
