Minwax poly over zar poly?
Forum topic by Sawlog posted 10-17-2016 06:01 PM 460 views 0 times favorited 2 replies Add to Favorites Watch
View Sawlog's profile
5 posts in 522 days
10-17-2016 06:01 PM
New here, thanks for the add. I’m having fits with this zar classic poly I’m trying. Can I put another brand of poly over the zar?
2 replies so far
View brtech's profile
1027 posts in 2858 days
#1 posted 10-17-2016 06:40 PM
There is sometimes concern with waterborne over oil based; are both the Zar and the Minwax the same base? Assuming you let the Zar dry thoroughly and scuff it up with 400 grit or something like it, it ought to be fine.
Not that Minwax poly is generally held in high regard. It’s okay, nothing great. The GF finishes are better I think.
Don’t forget to use gloss on all coats except the final one.
5 posts in 522 days
#2 posted 10-17-2016 06:53 PM
Thanks, both are oil based. And yes I have learned thru the years that you use gloss first.makes a big difference.
I have used minwax alot but I always get spots in the final coat and it drives me nuts, so I’m trying something new.
