Can a scrollsaw be used to shape a solid body guitar blank?
« back to Scrollsawing forum
Forum topic by Marn64 posted 10-17-2016 02:47 PM 1390 views 0 times favorited 13 replies Add to Favorites Watch
View Marn64's profile
Marn64
295 posts in 872 days
10-17-2016 02:47 PM
Topic tags/keywords: question scroll saw shaping
Hey everybody,
So I have been venturing into instrument making these past few months and I was wondering if a scrollsaw can be used as a substitute for a bandsaw when cutting out the shape of a solid-body guitar. Up until this point I have been using a crosscut hand saw to rough shape and then a coping saw for finishing cuts but it isn’t always that accurate. Is this possible or is it not advisable for reasons of safety, quality of cut, etc.
Thanks,
Benjamin
-- Benjamin, Milwaukee
13 replies so far
View Underdog's profile (online now)
Underdog
1153 posts in 2122 days
#1 posted 10-17-2016 04:10 PM
I’d much rather do that job on a bandsaw with a 1/4” or 1/8” blade.
View Planeman40's profile
Planeman40
1206 posts in 2847 days
#2 posted 10-17-2016 04:40 PM
A solid body guitar would be about 2” thick and of a hardwood. That is too much for a scroll saw. This would take a bandsaw or possibly a relatively large electric hand scroll saw with a finish cut blade.
Planeman
View Jim Finn's profile
Jim Finn
2666 posts in 3008 days
#3 posted 10-17-2016 04:42 PM
Scroll saws make a wonderful cut, much smoother than a band saw but most scroll saws have a 1 3/4” thickness limit.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
Marn64
#4 posted 10-17-2016 04:59 PM
- Jim Finn
The standard thickness of a 1950’s telecaster is 1 3/4 thickness, so is it doable?
View Redoak49's profile
Redoak49
3403 posts in 2075 days
#5 posted 10-17-2016 05:46 PM
Is possible….probably.. But will be difficult and very slow going. I would not do it.
Marn64
#6 posted 10-17-2016 06:27 PM
Would a handheld industrial quality jigsaw work better?
View SignWave's profile
SignWave
440 posts in 3121 days
#7 posted 10-17-2016 07:46 PM
Most guitar makers use a bandsaw or jigsaw to cut it close, then use a router with a patterning bit to finalize the shape, based on a template.
-- Barry, http://BarrysWorkshop.com/
Planeman40
#8 posted 10-17-2016 09:36 PM
“Would a handheld industrial quality jigsaw work better”
I believe it would work pretty well. Just last night I was using a Bosch industrial saber saw (“jigsaw”) to cut some 1 3/4” fir and it cut nicely to a curved line with a finishing cut blade. Make sure it is set up for an accurate cut 90 degrees to the surface of the wood. No matter what you use to cut, you will really need to cut a little outside of the line and use a 4” wide floor-type belt sander to finish sanding to the line for a nice smooth and accurate edge. Some people with expertise could finish hand sanding down to the line and do a nice job, but it would be a lot of work. I agree with SignWave above that the best way would be to make an accurate plywood pattern and use a router with a straight bit to pattern-cut down to the line after rough cutting slightly oversize.
Marn64
#9 posted 10-17-2016 09:38 PM
- SignWave
Jigsaw it is then huh, I don’t own the jigsaw and I am a hand tool woodworker by discipline, so are there any things I should know before using it?
Marn64
#10 posted 10-17-2016 09:39 PM
- Planeman40
thanks for the info, the body is spruce so I think it should cut quite well.
View TheFridge's profile
TheFridge
9879 posts in 1572 days
#11 posted 10-18-2016 12:28 AM
Rough it out about 1/16 larger than you want and spokshave it to the line maybe?
View marc_rosen's profile
marc_rosen
143 posts in 3267 days
#12 posted 10-18-2016 01:27 AM
Funny you should mention it…...
(Those Frank Zappa fans amongst you may enjoy that intro.)
I just finished cutting out a small electric “viola” for a friend yesterday. It was an 8/4 blank of hard maple and I used my bandsaw for the outside cuts and my Dewalt scrollsaw for the inside. My friend said he’d be happy if I had to use the bandsaw for all cuts and leaving a glued up saw kerf but I was certain I’d be able to do it if I kept my feed rate slow.
I broke about 5 blades in the process but I made two nice interior cutouts that only required minor sanding.
Hope this helps you decide which way to go. Marc
-- Windsurfing, Woodworking, Weaving, and Woodducks. "Most woodworkers are usually boring holes"
View ralbuck's profile
ralbuck
4858 posts in 2352 days
#13 posted 10-20-2016 06:50 PM
Scrollsaws will cut remarkably with care, blade lubrication, and PATIENCE!
I have used candle wax a a blade lube since 1953! The hint came with my first scrollsaw.
DO NOT try to cut too fast. Experiment on a chunk of wastewood first to get the feel, blade tension, feed rate etc. figured out.
Good luck and we will want to see the resuts too.
-- Wood rescue is good for the environment and me! just rjR
