Having issues with water cooled spindle?
« back to CNC Woodworking forum
Forum topic by WinecupWoodworks posted 10-17-2016 11:04 AM 675 views 0 times favorited 2 replies Add to Favorites Watch
View WinecupWoodworks's profile
WinecupWoodworks
2 posts in 497 days
10-17-2016 11:04 AM
Topic tags/keywords: cnc next wave automation cnc router router cnc shark spindle water cooled spindle
Hello!
I’ve got Next Wave Automation’s CNC Shark and purchased the water cooled spindle accessory.
It’s been fine for the first couple of months, no issues at all.
However, today the spindle started acting funny…The motor will turn on and ramp up the RPMs, but the bit won’t move at all. If I leave it, it gets to 13,000 RPMs and cuts off with an “EOCA” error code. I figured maybe the bit was catching, so after turning the motor on, I flicked it with my finger, which got it spinning. It’s not taking it up to speed though because the wood smokes as it cuts…
Any ideas as to whats going on? I took the spindle apart and cleaned out any dust/lubed it up to see if that was the issue, but no improvements.
Thanks for the help!
2 replies so far
WinecupWoodworks
2 posts in 497 days
#1 posted 10-18-2016 12:15 AM
Bump…
View Ger21's profile
Ger21
1074 posts in 3039 days
#2 posted 10-22-2016 04:48 PM
Call Next Wave. I’ve heard that they have good support.
It s not taking it up to speed though because the wood smokes as it cuts…
If it’s smoking, then the bit is probably spinning too fast, or the bit is very dull.
A bit spinning too slowly will not smoke, it’;ll just break.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
