bed headboard
Forum topic by Vjeko posted 07-04-2010 07:31 AM 1423 views 0 times favorited 5 replies Add to Favorites Watch
View Vjeko's profile
Vjeko
135 posts in 3378 days
07-04-2010 07:31 AM
Topic tags/keywords: question
Hi,
could I get a few ideas/opinions on what sort of headboard (design/how to attach it) I could use on
a bed such as this : http://www.cocobolo.de/massivholzbett-hiddensee.htm
but I’d like something nicer than what is shown on that web page. I want a headboard which is not plain vertical.
-- Vjeko Balas - Croatia
5 replies so far
View richgreer's profile
richgreer
4541 posts in 3038 days
#1 posted 07-04-2010 01:58 PM
I’m in the process of building a headboard that is like this one – -
http://www.finewoodworking.com/Gallery/GalleryImage.aspx?id=27538
A variation on that style may look good on the kind of bed you are making.
As an FYI – I am using a cherry frame and curly maple inserts.
Vjeko
#2 posted 07-05-2010 08:00 AM
Rich, my problem is that as you can see from the web page I mentioned, the bed comes together
just by crossing the frame members using slots and I’m not sure whether I can just extend the frame member
in height to make a true headboard (unsure of stability). Secondly, I was thinking of going
a bit more fancy and making the headboard curved (even thought about using something like a couple of
stainless rods onto which I would fit the headboard pieces – but would appreciate any pointers if someone has already experimented in this area). The headboard which is on the web page is I guess just two vertical
pieces each screwed at two points to the frame member and the horizontal pieces added – somehow I get the feeling this is not very strong for leaning your back into it.
richgreer
#3 posted 07-05-2010 01:16 PM
I see your point. My bed will have a more conventional design and stability should not be an issue.
I think the key question for you is how stable does a headboard need to be. It is essentially a decorative item and is subject to very little stress.
View woody57's profile
woody57
650 posts in 3391 days
#4 posted 07-10-2010 10:09 PM
was there a headboard on that site?
-- Emmett, from Georgia
Vjeko
#5 posted 07-11-2010 02:58 PM
as I wrote, their headboard is 2 vertical pieces (presumably screwed at two points each) and then
the horizontal pieces (looks like a fence ;) (OK, everyone has a different perspective on things ;)).
I want something that is incorporated into/with the frame member and would prefer some curvature to the headboard and it should be solid so you’re not worrying if you’re leaning against it.
Emmett – I don’t want to detract from your woodworking enjoyment, but shouldn’t you put that baby down before doing any more woodwork ? ;)
