Circuit requirements for 5 horsepower motors
Forum topic by Randy L. posted 07-04-2010 07:09 AM 1010 views 0 times favorited 1 reply Add to Favorites Watch
View Randy L. 's profile
Randy L.
19 posts in 2934 days
07-04-2010 07:09 AM
Topic tags/keywords: table saw planer hosepower hp 5 motor circuit electrical
I have a 5 horsepower motor on my 12 in Grizzly tablesaw and was wondering what gauge wire I should be using as well as what type/size of breaker I need. I am a little confused because the motor is rated at 30 amps (stamped on the motor), but in the equipment manual it says the saw should be fused at 30 amps. I’m sure someone on here can clear this up for me!
I also have a planer with a 5 horsepower motor. This motor is rated at 25 amps. Again, what size wire and breaker do I need? I will have dedicated circuits for each of these pieces. Thanks for the help!
-- Randy - Milton, WI
1 reply so far
TopamaxSurvivor
18267 posts in 3671 days
#1 posted 07-04-2010 07:13 AM
The code says #8 wire, 60 amp breaker or 40 amp dual element time delay fuses on 240 volts.
