Finish for workshop projects
Forum topic by mathom7 posted 07-04-2010 05:24 AM 1217 views 1 time favorited 9 replies Add to Favorites Watch
View mathom7's profile
mathom7
69 posts in 2934 days
07-04-2010 05:24 AM
I was wondering what everyone uses to finish there projects intended for the workshop: carts, stands, workbenches etc.
I haven’t finished any of mine yet, but, was just thinking of using some stain and polyurethane left over from a project for my wife.
Thanks
9 replies so far
View SnowyRiver's profile
SnowyRiver
51457 posts in 3503 days
#1 posted 07-04-2010 05:29 AM
I think if you are going to finish shop items, the stain and poly are the best.
-- Wayne - Plymouth MN
117115 posts in 3600 days
#2 posted 07-04-2010 05:34 AM
water base poly
View Andrew's profile
Andrew
709 posts in 3222 days
#3 posted 07-04-2010 05:36 AM
Boiled linseed oil for the workbench, poly won’t protect against the abuse it will take, it might as well feel natural and warm.
-- Even a broken clock is right twice a day, unless, it moves at half speed like ....-As the Saw Turns
View trifern's profile
trifern
8135 posts in 3790 days
#4 posted 07-04-2010 06:04 AM
Blood, sweat and tears…
View Rick's profile
Rick
9701 posts in 3056 days
#5 posted 07-04-2010 06:49 AM
trifern: I know that Group. They put out some great songs! David Clayton Thomas?
mathom7: Don’t tell anyone I did this but …...My Workbench isn’t like most of the “Pro’s” on here ;-} It takes a real beating and it has a 5/8”, OSB Well Supported Top.
Started to look a little “Ratty” so I ran over it quickly with a Belt Sander to get rid of all the High and Torn Out Spots. Then Diluted a Bottle of LePages Woodworking Glue with Water 50/50. Smoothed that off with a Wide Blade Paint Scraper. Let it Dry for 2 Days just to make sure. Another Quick Hand Sanding. Put a Coat of Minwax “Water Base Stain” “Burnt Orange”, which is more lika Paint than a Stain in my Humble Opinion. Let Dry overnight. 3 Heavy Coats of Water Base Poly and All Done.
In a Nutshell. Same as what Jim and Wayne said. Actually “Sealing Up” that OSB was a good move.
Also: Poly can might or might not say it but, while Poly seems to dry very fast it actually takes a full week for it to get to full Dry/Hardness.
Rick
-- LIFE is what happens when you're planning on doing Other Things!
TopamaxSurvivor
18285 posts in 3699 days
#6 posted 07-04-2010 07:08 AM
A little blood once ikn a while ;-)) Wax or tape to keep glue or epoxy from sticking.
View Pete_Jud's profile
Pete_Jud
424 posts in 3776 days
#7 posted 07-04-2010 07:15 AM
I use a lot of Seafin teak oil on projects, its a combo of tung and poly wipe on wipe off 6 coats, with a long time between coats, but the finish is great I get it from Daly’s in Seattle, but they have dealers all over the country.
-- Life is to short to own an ugly boat.
View Sailor's profile
Sailor
543 posts in 3288 days
#8 posted 07-04-2010 05:01 PM
Poly is what I use for nearly everything in the shop. My workbench, cabinets, sawhorses, router table, and saw horses are covered with poly, I love that stuff.
-- Dothan, Alabama Check out my woodworking blog! http://woodworkingtrip.blogspot.com/ Also my Youtube Channel's Facebook page https://www.facebook.com/SailingAndSuch
View PurpLev's profile
PurpLev
8536 posts in 3672 days
#9 posted 07-04-2010 05:04 PM
Boiled Linseed Oil!
it penetrates the wood and protects/seals it from moisture (which is all you really want) but does not leave a hard film finish which is smooth and can crack when banged on. this also leaves the warm soft wood to the touch.
when I secure something to my bench, or when I hit something with a mallet, or hold a tool in my hand, the last thing I want is for the tool/piece/mallet to slip away because they have a smooth finish on them.
your miles may vary.
