Casters with no play in them... Help?
Forum topic by JohnMcClure posted 10-15-2016 09:19 PM 2544 views 0 times favorited 18 replies Add to Favorites Watch
View JohnMcClure's profile
JohnMcClure
400 posts in 880 days
10-15-2016 09:19 PM
I bought 4 locking swivel casters from the big box store for my router table base.
http://www.lowes.com/pd/Waxman-3-in-Polyolefin-Swivel-Caster/50392288
They are perfect in every way except… when locked, there is just a little bit of play at the swivel, so the wheel can “wobble” a little bit. It can’t turn, it can’t swivel, but it can camber a couple of degrees. This adds up to a router table that can sort of rock under side load – a disaster waiting to happen!
Any recommendations for similar size and relatively cheap casters that won’t have this kind of play in them?
-- I'd rather be a hammer than a nail
18 replies so far
View distrbd's profile
distrbd
2252 posts in 2686 days
#1 posted 10-15-2016 10:01 PM
For a router table I would highly recommend dual locking casters like Kreg ,they lock on and won’t wobble , I use them on my shop made RT and have zero complains:
https://www.amazon.com/Kreg-PRS3090-Locking-Caster-Set-Piece/dp/B000SR5YBA/ref=sr_1_1?ie=UTF8&qid=1476568966&sr=8-1&keywords=Kreg+casters
-- Ken from Ontario, Canada
View dhazelton's profile
dhazelton
2805 posts in 2536 days
#2 posted 10-15-2016 10:55 PM
You’re talking about when you hold one in your hand and push on it side to side? I would think when you have 4 of them each at a different spot as far as their rotation is concerned PLUS weight on them they would be fine. But you won’t know until you try.
JohnMcClure
#3 posted 10-16-2016 02:03 AM
Hazelton, exactly – and noticing that at the store, I also reasoned that they would be fine with all 4 in different directions. But now that I have them on there it’s just too sloppy for a router table, IMO.
View Redoak49's profile
Redoak49
3743 posts in 2228 days
#4 posted 10-16-2016 02:15 AM
Unfortunately, good double locking casters are not cheap. I have had good luck with the ones from Woodcraft.
dhazelton
#5 posted 10-16-2016 12:43 PM
I recently was putting a new drive wheel and bearings on my old Snapper walk behind mower. The new bearings had way more slop than the old ones did. Things aren’t made like they used to be.
View JAAune's profile
JAAune
1854 posts in 2556 days
#6 posted 10-16-2016 06:02 PM
I use double-locking casters made by Rhombus and sold via sources such as McMaster Carr. By the time shipping is factored in expect to pay around $160 for a set of 4. It sounds expensive until one considers that they provide flawless mobility and service for a lifetime. Cheap casters provide a few years of hassle and frustration before they get pitched and replaced with something better.
View AlaskaGuy's profile
AlaskaGuy
5000 posts in 2549 days
#7 posted 10-16-2016 06:27 PM
Good caster are not cheap, you get what you pay for.
View 000's profile
000
2859 posts in 1139 days
#8 posted 10-16-2016 06:48 PM
View MikesProjects's profile
MikesProjects
172 posts in 2141 days
#9 posted 10-16-2016 08:27 PM
I just put these on my router table last week, im very happy with them, they look just like yours but I got them from the depot http://www.homedepot.com/p/Everbilt-3-in-Polyurethane-Swivel-Caster-with-Brake-4120545EB/203672194
I went to purchase an additional set but they were all sold out, I plan on using these more often, I wqs impressed. For me they lock in tight with little or no play & made the heavy router table portable, with all four locked its super tight. I don’t recall the table deflecting even a little while in the locked position, for me they work perfectly. My router table is heavy though so perhaps that makes a difference.
-- -Mike, Southern California, YouTube User ( Give & Take )
View MrUnix's profile
MrUnix
7107 posts in 2438 days
#10 posted 10-16-2016 09:15 PM
When I was building a mobile base, someone suggested these: Steelex D2612 5-Inch 300-Pound Swivel Double Lock Polyurethane Plate Caster at around $12 a piece. I also found what looks like the identical double locking caster at my local Tractor Supply for roughly the same price.
In the end, I decided that to provide maximum stability, the base needed to rest directly on the floor when in use, and the casters should only be engaged when moving it – similar to those rockler lifting casters mentioned above that are foot operated. Unfortunately, they can only support 100lbs each, and my base was for a machine in excess of 600 pounds. Final solution was to make my own lifting caster bracket out of scrap metal, a couple nuts/bolts and a $4 swivel caster from HF:
Probably not an option if you can’t weld or don’t have any metalworking experience, but a fun project if you do :) But for something like a router table that doesn’t weigh as much, the Rockler ones might work as well.
View robscastle's profile
robscastle
5632 posts in 2444 days
#11 posted 10-16-2016 09:51 PM
Hello John,
You may wish to consider making the two front wheels fixed and see if the stability issue resolves itself.
It sounds like you have got too many steering wheels and producing cumlative stabiliy errors.
A few pictures of the router set up would assist in providing useful feedback advice too.
I looked at your caster and its certainly appears to be design wise fit for purpose, again a picure of everything helps.
-- Regards Rob
View GR8HUNTER's profile
GR8HUNTER
5396 posts in 952 days
#12 posted 10-16-2016 09:57 PM
Maybe something like these.
http://www.rockler.com/workbench-caster-kit-4-pack
- jbay
i like these good idea
View oldnovice's profile
oldnovice
7380 posts in 3607 days
#13 posted 10-17-2016 01:12 AM
I always buy my casters at Caster City and never had a complaint.
Size, operation, wheel type, locking type, delivery, price, and whatever, you can’t go wrong with their products.
It appears that the caster you are using is only a rolling lock and not a swivel lock.
Caster City has both types of locking types available.
I have used a number of them and when these lock, there is NO play!
View MadMark's profile
MadMark
979 posts in 1692 days
#14 posted 10-17-2016 01:18 AM
Only put two casters on and the other two legs run to the floor. Attach side handles and move like a wheelbarrow.
M
View Woodchuck2010's profile
Woodchuck2010
724 posts in 1098 days
#15 posted 10-17-2016 01:27 AM
Probably not an option if you can t weld or don t have any metalworking experience, but a fun project if you do :) But for something like a router table that doesn t weigh as much, the Rockler ones might work as well.
- MrUnix
Bingo! Buy a mobile base that sets the whole base down on adjustable feet. Like this HTC.
https://www.amazon.com/Adjustable-Mobile-Power-Tools-HTC-2000/dp/B00002262M/ref=lp_552520_1_1?s=power-hand-tools&ie=UTF8&qid=1476667369&sr=1-1
Very solid!
-- Chuck, Michigan,
