Anyone have a ideas for sawblade storage?
« back to Coffee Lounge forum
Forum topic by jusfine posted 07-04-2010 04:57 AM 1725 views 0 times favorited 11 replies Add to Favorites Watch
View jusfine's profile
2422 posts in 2860 days
07-04-2010 04:57 AM
Topic tags/keywords: question
I have a number of 10” and 12” blades that I need to build storage for, what is your preferred method?
-- Randy "You are judged as much by the questions you ask as the answers you give..."
11 replies so far
View Steven H's profile
Steven H
1117 posts in 2994 days
#1 posted 07-04-2010 05:19 AM
Hang it with a peg, duct tape it to the wall, make a rack…
View richgreer's profile
4541 posts in 3008 days
#2 posted 07-04-2010 02:08 PM
I have a 1×10 oak board and I have mounted several pegs (dowels) into it at a slight upward angle. The board is attached to a wall.
View Gene Howe's profile
Gene Howe
10260 posts in 3362 days
#3 posted 07-04-2010 03:03 PM
Similar to Rich’s idea, take a couple 2X6s and cut angled kerfs in them and mount them side by side on a wall.
Or, build a box with hard board “Shelves” that slide in kerfs in the sides of the box. Like a paper file holder….sorta.
That’s what I did for blades and sand paper.
View knotscott's profile
7938 posts in 3309 days
#4 posted 07-04-2010 05:17 PM
This one is easy and works well…prolly similar to what Gene described. They’re still exposed to dust though, and you have to be careful not to rub against it!
#5 posted 07-04-2010 06:03 PM
I have a plywood “rack” similar to the one in the photo above by knotscott, but I like the idea of simple drawers instead.
Thanks for the suggestions and links.
View stefang's profile
15878 posts in 3268 days
#6 posted 07-04-2010 07:41 PM
I like vertical or horizontal pigeon holes. Takes minimal space and protects against getting snagged by them.
View WoodSawyer's profile
3 posts in 2314 days
#7 posted 11-20-2011 08:59 AM
404 - Not Found
2544 posts in 2903 days
#8 posted 11-20-2011 02:26 PM
I keep them in their original cardboard sleeves stacked on top of each other. They don’t take up much room that way and you don’t have to mess around when you take them for sharpening.
View Bertha's profile
13510 posts in 2627 days
#9 posted 11-20-2011 08:10 PM
I don’t have much of a blade collection. If I have to change a blade, I’ll usually just find another way to make the cut. Does that make me weird? I hate changing blades. Or rather, I hate checking setups after I’ve changed blades. Don’t even get me started about bandsaw changes;)
#10 posted 11-20-2011 08:15 PM
Wow, I had forgotten I even posted this…504 days ago.
This is what I ended up with for my storage, incorporated into my outfeed table for my Unisaw.
See blog here.
View Jim Jakosh's profile
Jim Jakosh
20169 posts in 3039 days
#11 posted 11-21-2011 02:21 AM
I stack mine in the cabinet I built below my table saw. I put a round cardboard disc in between each one to protect the edges from hitting. I only have about 4 and don’t change them much. I don’t like leaving them out where I can bump into them They cut you pretty quickly just standing still!...........Jim
