O-Rings for router bit placement in the collet
Forum topic by Desert_Woodworker posted 10-15-2016 06:48 PM 533 views 0 times favorited 2 replies Add to Favorites Watch
View Desert_Woodworker's profile
Desert_Woodworker
1308 posts in 1118 days
10-15-2016 06:48 PM
Topic tags/keywords: router cnc router collets tip question trick
I use routers/spindles and I have to manually place the bit correctly in the collet. Regardless, whether the machine is on the top or the bottom – I have to make sure that it is correctly set just right. The problem sometimes, is that the placement of the bit moves in the collet. Recently, I heard about O-rings used for proper placement of the bit. Here is a video that shows how it is done https://youtu.be/q3h3R2-YgtY as he says in the vid- remove the O-ring after machining so that it does not “lock” in the collet. I would like to hear more about this method and share some feedback to me and others.
-- Desert_Woodworker
2 replies so far
4873 posts in 2397 days
#1 posted 10-15-2016 07:01 PM
I do it all the time, at least with some bits. I leave the o ring on the bit and have no idea (I didn’t watch the video) what he means about “lock” in the collet. The o rings do stretch (I guess) over time so they need replacing periodically. I grabbed a handful at the hardware store, but they are available from some of the specialty woodworking vendors. I don’t see them as a precision placement device, if that’s what you want. More of a handy way to hold them in roughly the right place while you tighten the collet.
View TheDane's profile
TheDane
5365 posts in 3567 days
#2 posted 10-15-2016 07:05 PM
While I see what he is trying to do, I really think it is more of a solution in search of a problem than vice-versa.
While the o-ring will provide a cushion between the end of the shank and the bottom of the collet, my gut tells me you would either be chasing o-rings around the shop, or digging them out should the router get hot enough to melt them.
I am not into CNC work, so I am not dealing with a spindle that is fixed above the work surface. In a conventional router table, raising the bit a 1/16th has never been an issue for me.
