Bosch Router & Leigh Jig Help
Forum topic by Maveric777 posted 1054 days ago 1945 views 0 times favorited 4 replies Add to Favorites Watch
View Maveric777's profile
Maveric777
2593 posts in 1246 days
1054 days ago
Topic tags/keywords: question router jig dovetail jig bosch leigh
Well me being new to woodworking reared its ugly little head again today. I went out to the shop planning on figuring out my Leigh Super Jig. I removed my Bosch 1617 router from its table, gathered all the stuff for it, and found I can’t attach the Leigh e7 bushing to my router.
Here is a pic of the Bosch supplied template guide adapter (left) and the Leigh supplied e7 bushing (right)
I am assuming I need another part (either from Bosch or Leigh) to get the bushing attached. I plan on doing more research, but figured I would ask here as well. I’m lost…lol
Thanks for the help..
-- Dan ~ Texarkana, Tx.
View TomHintz's profile
TomHintz
207 posts in 1568 days
#1 posted 1053 days ago
You need to either get the Leigh adaptor for your router or get a PC style baseplate for your router. If you remove the baseplate from your router you should find another bolt pattern (3-hole pattern) which you can use to install a PC baseplate from their 890 series routers. There are lots of aftermarket baseplates available also, including some for centering the guide collar on the router. I like using these centering baseplates because most routers can benefit from that little bit of alignment. The Leigh jig is so accurate that getting the baseplate/guide collar perfectly centered can make a difference in joint fit. See the link below for a story I did on this type of baseplate.
Centering Your Guide Collar
-- Tom Hintz, www.newwoodworker.com
Maveric777
#2 posted 1053 days ago
Thank you Tom. I never thought of trying to find an aftermarket base plate. I did find where Leigh has a bunch of adaptors for different routers, but I’m not confident on what to order. I will look into an aftermarket base .
View PurpLev's profile
PurpLev
7753 posts in 1818 days
#3 posted 1053 days ago
most (if not ALL) 3rd party companies that make router accessories are using the PorterCable style connection for their bushing as stated already.
have you tried contacting Leigh directly to ask them which part number to get? this would take the guessing game out of the picture :)
View thewoodmaster's profile
thewoodmaster
53 posts in 1362 days
#4 posted 1053 days ago
Leigh sells adapters for attaching their e bushing to different routers. http://www.leighjigs.com/ugs.php This link takes you to their page with the information on how to figure out which one you need.
-- dan "insert pithy woodworking coment here"
