Something about this cope and stick doesn't look right.
« back to Joinery forum
Forum topic by jtcarn posted 10-15-2016 03:23 AM 725 views 0 times favorited 6 replies Add to Favorites Watch
View jtcarn's profile
jtcarn
12 posts in 859 days
10-15-2016 03:23 AM
I’m finally getting to my door build. Using an MLCS rail and style set. I swear I have this set up right using setup blocks. The joint is tight, but something about the corner doesn’t feel right. Is this how it’s supposed to look? If not, what am I doing wrong?
View BurlyBob's profile
BurlyBob
5858 posts in 2352 days
#1 posted 10-15-2016 03:45 AM
Yeah, that doesn’t look right. Looks to me like you used the same bit to cut both. I’ve never seen a stile and rail like that. Why don’t you check out You Tube. The wood whisperer has a decent video there. It might lead you in the right direction.
jtcarn
#2 posted 10-15-2016 04:12 AM
Thanks. Definitely not using the same bits and both profiles match the setup blocks exactly. Baffled. I don’t see how that joint could be any different, even though my existing cabs look like the corners are at a perfect 45.
View skipj's profile
skipj
97 posts in 2359 days
#3 posted 10-15-2016 01:44 PM
Send your post,including photo, to MLCS. They will tell you what is wrong.
They have very good customer service.
View Nubsnstubs's profile
Nubsnstubs
1336 posts in 1816 days
#4 posted 10-15-2016 03:09 PM
It looks like a mitered corner and the piece has been shaped. Your cuts look straight, but with the shaped face, it will not have the straight look. If your frame was just a flat wood, you still wouldn’t have a matched miter. Stick and cope is for butte joint type joints, not miters…...... Jerry (in Tucson)
View michelletwo's profile
michelletwo
2750 posts in 3102 days
#5 posted 10-15-2016 03:45 PM
I agree with Jerry..it is for butt joints not miters
View jerryminer's profile
jerryminer
937 posts in 1527 days
#6 posted 10-15-2016 06:09 PM
Your cope-and stick set is working fine. Your set-up is right. That is a “normal” joint.
Other cope-and-stick profiles will look more like miters. That ogee profile has two “level” spots that end up looking like butt joints (because they are butt joints).
To better imitate a miter, you can take a knife and cut the feather edge at the corner as shown here:
