Dust Collection Question
Forum topic by twoblacklabs posted 10-15-2016 12:35 AM 1448 views 0 times favorited 22 replies Add to Favorites Watch
View twoblacklabs's profile
twoblacklabs
262 posts in 2833 days
10-15-2016 12:35 AM
Maybe this is a stupid question that has been answered over and over but I can’t find a logical answer. If one adds a chip separator (typical hf 2hp dust collector setup), why in the world do you STILL need a collection bag? It seems to me that it already HAS a chip separator as the chips fall into the plastic bag.
Would someone please explain the advantage of adding a separator up stream of the collector itself and then having a bag?
Thanks for the enlightenment.
John
-- If You Haven't Got the Time to Do It Right, When Will You Find the Time to Do It Over?
22 replies so far
View Joe Lyddon's profile
Joe Lyddon
10265 posts in 4194 days
#1 posted 10-15-2016 12:48 AM
Good question…
In my case, I have a filter in my Shop Vac that is absolutely USELESS because of the Dust Deputy in front of it… besides being there in case the DD filled up & the stuff had to go somewhere… (??) I will never have to buy another Filter bag for it! :)
View Holbs's profile
Holbs
1958 posts in 2171 days
#2 posted 10-15-2016 04:22 AM
Using a separator does the job upon chips and large dust particles. Depending on the item (Thein baffle or dust deputy or such), you could get 80-90%, as it was designed to do. But what it’s not designed to do is capture 100% fine dust that does get thru to your bag/filters. I have a top hat thein baffle and dual wynn filters on my grizzly 3hp for that reason.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
5088 posts in 2635 days
#3 posted 10-15-2016 11:10 AM
What Holbs said: thinking it will get everything will simply fill your shop with the finest dust particles. But what it does allow is to vent outside (if other conditions, like heat loss permit) in which case the fine particles will be scattered by the slightest breeze to parts unknown (or your neighbors black Mercedes).
twoblacklabs
#4 posted 10-15-2016 02:56 PM
That all makes sense but my confusion remains. Maybe I need to say it a different way.
In a single stage dust collection system, the chips and dust come into intake and then begin to spin in a conical fashion, dropping the chips into the collection bag while the filter bag grabs the dust (in my case, up to 5 microns) which build up on the upper filter bags walls, creating a “thicker” filter. When the system is shut off, the loose dust ALSO falls into the lower collection bag. Turn it on and the cycle begins again. Thus, the chips and a large amount of dust collect in the lower collection bag. You then must change out the bag as needed.
In my mind, I see the add on cyclone, chip separator (or whatever one chooses to use) doing essentially the same thing. The rotating air flow with the aid of gravity, drops the heavier particles in the add on chip collector. The lighter, fine dust continues to the upper filter bag/cartridge. Once the unit is turned off, the floating fine dust would in turn, drop down into the existing collecting bag. Thus, essentially , the exact same process has happened.
What I can’t grasp, is why we would want to go to the trouble of adding the cyclone/separator/dust deputy (etc). Clearly, others have understood the benefit but I am missing it. There has to be a simple explanation. Obviously I’m thick headed because I can’t figure it out. Other than a convenience of not having to unlatch the metal band that holds the original collection bag, pulling the plastic bag away, what is the benefit?
It’s not a matter of “if you don’t want it, don’t do it”. I’m seriously trying to understand this as it’s been bugging me for awhile.
Thanks for helping.
John
View Tommy Evans's profile
Tommy Evans
148 posts in 2316 days
#5 posted 10-15-2016 03:19 PM
>>>>What I can’t grasp, is why we would want to go to the trouble of adding the cyclone/separator/dust deputy (etc). Clearly, others have understood the benefit but I am missing it. There has to be a simple explanation.<<<<<
I think in this situation, the chip separator is used because it’s MUCH easier to empty and set back up than the bag attached to the HF dust collector. The bag then would be left for back-up and may only need to be emptied monthly or yearly or never (depending on usage).
It also keeps large pieces and nails and nuts and bolts from going thru the impeller.
peace, T
#6 posted 10-15-2016 03:29 PM
^^^^^^^^ there ya’ go. In the case of a cyclone, a well designed one will actually separate out much of the fine dust so it never gets to the filter, insuring you have maximum air flow for a much longer time. A less well designed one still drops some of the fines into the bag, but not all. Also, if you have a cyclone, the impeller doesn’t have to be built to withstand impacts of chunks, so they can be of a lighter, more aerodynamic design.
Holbs
#7 posted 10-15-2016 03:56 PM
A separator does 3 main purposes: saves the dust collector impeller from damage (as heard in my test run video below), saves wear & tear on my $300 air filters, and easier to unload 55gallon plastic bin than the dust collector bags themselves.
View on YouTube
twoblacklabs
#8 posted 10-16-2016 01:27 AM
Thanks for all of the replies.
Preventing impeller damage seems to be the biggest advantage with the additional ability to empty into something other than the collection bag.
View Rentvent's profile
Rentvent
151 posts in 991 days
#9 posted 10-16-2016 02:25 AM
If you have a decent separator in front, you don’t need the lower clear plastic bag anymore.
http://lumberjocks.com/projects/106615
There’s also youtube videos showing the bottom bag replaced with a round piece of plywood.
Joe Lyddon
#10 posted 10-17-2016 08:16 PM
It’s EASIER to empty a Dust Deputy bucket than a Shop Vac and it’s Filter… BY FAR!
My Filter bag doesn’t look like it has caught much dust at all!
... it still SUCKS BIG TIME!
SUCKS GOOD and STRONG, it seems forever… NEVER dropping because of a clogged Filter, etc. etc.
View MJCD's profile
MJCD
557 posts in 2513 days
#11 posted 10-19-2016 01:29 AM
twoblacklabs:
There are several advantages to the pre-impeller separator… and damage to the impeller, though a possibility, is not the most important – IMO.
1) Cyclones provide for a more efficient air stream – which is why a Thein separator has a lower separation efficiency than say a Super Dust Deputy (SDD) or a full cyclone system.
2) Removing the chips earlier within the air stream means that the impeller has less debris to move, overall – think of it in terms of debris-feet (how many feet are you moving an amount of debris – something like 100 people on an airplane flying 100 miles is 10,000 passenger miles); and there is less air turbulence (technically, less ‘static pressure loss’) going through the impeller – at this point, it’s probably some fraction of 5 micron dust.
3) Some element of the really small stuff still gets through; and if there’s a clear plastic bag to collect it, well, that’s good; otherwise, the extra stuff ends-up in your filters – Clearvue designs-in a ‘catch-box’ at the bottom of the Wynn Filters stack – mine accumulates stuff when I forget to change my primary dust bid.
I’ve owned the SDD, and it’s excellent – it does limit you to a 4” or 5” main run, which in-turn limits you to drawing from one machine at a time. That said, they are worth the money.
MJCD
-- Lead By Example; Make a Difference
View Puzzleman's profile
Puzzleman
417 posts in 3086 days
#12 posted 10-24-2016 06:06 PM
Joe said it best of all. The reason for adding a dust separator is that the suction does not decrease as the dust builds up. Having it easier to empty the dust bin is a plus, but the main thing is that you have maximum air flow through the suction tube. This is what catches all of the dust.
As far as a filter afterwards, the filter catches the 5% to 10% of fines that are not caught by the separator.
-- Jim Beachler, Chief Puzzler, http://www.hollowwoodworks.com
View Rob_s's profile
Rob_s
251 posts in 763 days
#13 posted 11-06-2016 12:52 PM
For me, the benefits on a shop vac seem silly, while the benefits on a true dust collector are pretty tangible.
Adding a cyclone to a shop vac results in me emptying a bucket-type vessel, which I would do with a shop vac anyway, at the cost (time, money, or both) of all the hardware required and the added bulk. I’d rather just keep a supply of filters on hand, personally. Just doesn’t pan out IMO.
On a larger true dust collector, you’re talking about emptying a bucket vs a bag (bucket is easier) as well as reducing clogs and extending life on a much more expensive filter, or not having to deal with a filter bag. Not to mention protecting the blades as already noted.
It occurs to me, as I write this, that a shop vac already operates as somewhat of a cyclone as the dust is sucked into the vessel, not through the fan.
-- www.facebook.com/therealbnrlabs
Joe Lyddon
#14 posted 11-06-2016 05:14 PM
Adding a cyclone to a shop vac results in me emptying a bucket-type vessel, which I would do with a shop vac anyway, at the cost (time, money, or both) of all the hardware required and the added bulk. I d rather just keep a supply of filters on hand, personally. Just doesn t pan out IMO.
On a larger true dust collector, you re talking about emptying a bucket vs a bag (bucket is easier) as well as reducing clogs and extending life on a much more expensive filter, or not having to deal with a filter bag. Not to mention protecting the blades as already noted.
- Robs
Robs… You obviously have NOT tried it… Try it, you will LOVE the FULL SUCTION mode ALL of the time… and NOT have it get weaker & weaker as the filter gets clogged up…
View bkseitz's profile
bkseitz
295 posts in 1452 days
#15 posted 11-06-2016 09:41 PM
John, The simple answer is that while almost all / all the chips get collected by the separator the finer dust will manage to get through. Thus a fine filter and bag/box are there for that. I’ve a mobile 1hp Rigid I’m working on to replace with a HF 2HP with a Wynn Filter and Super Dust Deputy.
The Rigid was connected to one of those trashcan lid separators. It worked o.k. considering. However, the bag still collected fine dust that also bled out of the bag—[5 micron?] This is why I’m working to replace it. In the meantime I’ve doubled up on protection using a 3m 7500 Dust Mask also
-- bkseitz, Washington "if everything is going well, you've obviously overlooked something"
