Best Joints For A Drill Press Table
« back to Joinery forum
Forum topic by jmalcolm001 posted 10-14-2016 12:00 AM 690 views 0 times favorited 6 replies Add to Favorites Watch
View jmalcolm001's profile
jmalcolm001
18 posts in 901 days
10-14-2016 12:00 AM
Topic tags/keywords: joints drill press table butt joint pocket hole joint dado lock miter router bit
I recently bought a new 15” floor drill press (Porter Cable PCB660DP), and want to build an expanded wood table/cabinet to hang from the existing cast iron table. I am undecided on how deep (vertically speaking) to make it and what kind of joints to use to join the vertical pieces to the top horizontal piece, and would like your recommendations.
I contemplate a design of two 3/4 ” pieces of plywood approx 30” x 18” sandwiched together for the top table and they will rest on and be bolted to the cast iron table. Attached vertically to the bottom piece of the plywood table will be 4 pieces of 3/4” plywood approx 18” wide and hopefully 16” long (vertical), but maybe shorter if it is felt that would add too much weight. Two of the vertical pieces will be attached at each end of the table and the other two pieces will be attached approximately 8” in from each end. Another piece of 30” x 18” plywood would be attached horizontally to the bottom of the vertical pieces.. I would like to add 3 drawers on each side and one larger drawer in the bottom middle. Most of the building plans that I have seen only drop down up to 10”, but I would like more drawer space, but worry that it might add too much weight.
I am undecided as to how to attach the 4 vertical pieces to the bottom table. I think this is very important because the entire table/cabinet and its contents will be hanging from those joints.
My joint alternatives are as follows in order of convenience:
1. Butt joints with glue and countersunk screws fastened from the top for all 4 joints (top table will hide the screws).
2. Pocket hole screws from the inside and possibly glue and additional countersunk screws fastened from top for all 4 joints.
3. Make a dado approx 3/4” down from the top of the vertical end pieces and place the ends of the bottom table top in them along with glue. Maybe also countersunk screws from the top. The two inside vertical pieces would be attached using one of the above methods.
4. I have a new Freud lock miter router bit that I was planning on using for the drawers, but I could probably also use it for the adjoining ends of the outside vertical pieces and the table along with glue and maybe even countersunk screws from the top. The inside vertical pieces would use one of the first two methods.
The bottom of the vertical pieces could be attached to the bottom horizontal piece in one of the above ways also.
I would appreciate your recommendations as to what joints to use, and whether I am trying to make the cabinet part too big.
-- Jerry
View MadMark's profile
MadMark
979 posts in 1602 days
#1 posted 10-14-2016 06:13 AM
Biscuited & glued butt joints for plywood. Make the sides full height and the top / bottom inset as hangers.
M
View HokieKen's profile
HokieKen
6299 posts in 1288 days
#2 posted 10-14-2016 12:44 PM
I constructed my DP table very similar to what you’re doing except I used MDF instead of plywood.
For the joints, I used rabbets and dados to ensure proper location. If using plywood, the biscuits and glue like Mark suggests should be just fine. If you don’t have a plate jointer, you can use some screws or brads to hold location while gluing up. I don’t know if I’d use pocket screws in plywood when you’ll have that much weight “hanging” from the top. Other than that, I think any of the methods you’re considering will be plenty strong.
-- Kenny, SW VA, Go Hokies!!!
jmalcolm001
#3 posted 10-14-2016 01:57 PM
MadMark & HokieKen: Thank you for your comments. I guess I am a little surprised that both of you suggested the use of biscuits and glue. I would have thought that my alternative #3 using a dado in the vertical piece would have been a stronger joint, or did you suggest the biscuit so that I wouldn’t have to drop the horizontal piece down 3/4”? I wasn’t too concerned about the drop down, since the top most horizontal piece would fill in the 3/4 inch gap.
HokieKen: As many of the commenters said, your DP table is beautiful and looks like a piece of furniture!! Can you explain in a little more detail your use of rabbets and dados, and why you chose MDF vs plywood? I live in So Florida with high humidity, and my shop (garage) is not air conditioned, so I generally shy away from MDF.
-- Jerry
HokieKen
#4 posted 10-14-2016 04:42 PM
MadMark & HokieKen: Thank you for your comments. I guess I am a little surprised that both of you suggested the use of biscuits and glue. I would have thought that my alternative #3 using a dado in the vertical piece would have been a stronger joint, or did you suggest the biscuit so that I wouldn t have to drop the horizontal piece down 3/4”? I wasn t too concerned about the drop down, since the top most horizontal piece would fill in the 3/4 inch gap.
- jmalcolm001
My reasoning for using biscuits would simply be because it’s easier. Personally, I’d go the rabbet and dado route.
I chose MDF because I’ve used it and plywood both in the past and I find MDF with formica laminate to be the most stable and the flattest to begin with. YMMV of course. If I were to use plywood, I’d go with Baltic Birch at least for the top. The typical home center stuff has too few plys to be really stable and I’m usually lucky to find a sheet that’s flat to begin with. Again, YMMV.
My table has a top that’s 2 layers of 3/4 mdf laminated together with formica on top. On the bottom side of the top, I routed dadoes for the 4 (1/2” MDF) vertical pieces. Then the bottom is 3/4”MDF as well. The 2 center vertical pieces are dadoed into the bottom as well. The bottom has 1/2” wide rabbets cut for the 2 outer vertical pieces. Then I cut 2 pieces of 1/2” MDF that fit the “holes” on the back of the table where the drawers go and just butt glued them in. They’re really just there for a little added structure.
Hope that explains it well enough. Below is a quick sketch to try to illustrate what I’m saying:
jmalcolm001
#5 posted 10-14-2016 06:40 PM
Thanks again for your insight. Your illustration helps me understand your structure. But it does bring up a couple of questions. If your two pieces of 3/4” MDF are laminated together, how do you fasten them to the DP metal table, or do you just rest them on the table and use cleats to keep it from moving? Also, I see from your illustration the dados in the bottom top piece, but do you just use glue to attach the vertical pieces into the dados. That doesn’t seem strong enough with just glue, or am I missing something? I was thinking about having the outside verticals extend all the way up even with the top top piece, and then putting a dado in those two verticals 3/4” down from the top so that the bottom top piece could be inserted and glued into those dados. The bottom top piece would extend by the depth of the dado longer than the top top piece on both ends. That method seems like it would be the strongest of the joint methods that we have been discussing.
After looking at your illustration and doing some more thinking, maybe I am looking at this all wrong!! I was planning on setting the bottom top piece on the DP table and bolting it to keep from moving, similar to how you did. However, since the DP table is adjustable up and down, why not move the DP table down further and set the whole wooden table and cabinet on top of the DP table and bolt the DP table to the bottom piece of the cabinet. That way I would not have to worry about weight and strength of joints. My only concern is whether it would be top heavy and have a tendency to wobble since the table/cabinet is probably 2-3 times as wide as the DP table. What do you think?
-- Jerry
HokieKen
#6 posted 10-14-2016 06:56 PM
Yes, the glue in the dadoes is all there is and it’s been sufficiently strong. But, my drawers aren’t as tall as your thinking about. You may want to add some countersunk screws since the bottom of your’s will probably end up quite a bit heavier.
I put threaded inserts in the table top on mine to bolt it down to the table.
I don’t think I’d put the whole thing on top of the table. No matter how you build it, there will be some vibration. With the work surface bolted to the metal table, the vibration will be minimized. I think I’d stick to your plan as far as that goes. Of course, as long as you space your drawers far enough apart, you can always try it one way and then switch it if you don’t like it.
