Custom Table Top
Forum topic by CoryS posted 10-14-2016 12:00 AM 452 views 0 times favorited 1 reply Add to Favorites Watch
View CoryS's profile
CoryS
3 posts in 638 days
10-14-2016 12:00 AM
Topic tags/keywords: table top custom jig router shape unique question trick tip shaping modern
Hey everyone,
I’m going to be building a unique game table for a client. The table top will be a custom shape. The shape is kind of an oval but with both ends squared off. Rockler and other places sell router jigs for making elliptical shapes. And normally, I would use one of those and chop the ends off. However, the table top will be 6’ long and none of the jigs I’ve seen make 6’ ovals.
The table top will be made with 4/4 poplar and will be painted.
Here is a link to the plans for the table…
https://drive.google.com/file/d/0B4jWUZkHco9SOTBBd2JwaW1rbFE/view?usp=sharing
Can anybody share with me how I would accurately cut this out or somehow make a template?
-- Cory
1 reply so far
View diverlloyd's profile
diverlloyd
2730 posts in 1853 days
#1 posted 10-14-2016 12:46 AM
A piece of tempered hardboard would make a good jig. So you need the center line which would be 9” put a screw there and do the same on the other end. Now take a piece of string and tie it to both screws. Leave it loose enough to where the center of the string can stretch to the apex of the oval. Now you can take a pencil and push against the wrong or wrap the string around the pencil once and draw out your arc. You can cut it with a jig saw and sand it now you have a templet. http://www.mathopenref.com/printellipse1.html
Or you can take the length and height and do some geometry and find out the radius of the arc you want to draw and use a set of tremel points. At 6’ long and a 9” height you would be 6.375’ radius to draw the arc from. So there you have it 2 ways to draw the arc to make the guide. I like math.
