How would you Attach these wood strips ?
Forum topic by irish620 posted 10-13-2016 07:50 PM 426 views 0 times favorited 3 replies Add to Favorites Watch
View irish620's profile
irish620
37 posts in 2183 days
10-13-2016 07:50 PM
Hey Guys,
I’m making this decorative wall art piece from 2’’ wood scraps of ash, cottonwood and poplar. They are milled square to 3/16, 5/16, 1/2 and 3/4, cut to various lengths and then attached to a piece of shop grade 1/2 baltic birch measuring 48×82.
How would you attach these 200 pieces to the plywood ? Yellow glue or construction adhesive ? To clamp or not to clamp ? Taking into account expansion and contraction ? I would like to avoid brad nails but perhaps pin nails would at least hold in place while it drys without clamps.
Advise ?
Below is what I am replicating :
3 replies so far
MrUnix
6199 posts in 2074 days
#1 posted 10-13-2016 08:10 PM
Wood glue. Not sure if clamping would be necessary, but if you want to – perhaps a thickish piece of foam laid on top and then covered with a sheet of plywood and some weights would be sufficient. The foam would conform to the uneven surface and provide a more or less even pressure on all the pieces.
View shipwright's profile
shipwright
7854 posts in 2673 days
#2 posted 10-14-2016 06:40 AM
To answer the question, I would use hot hide glue.
- very fast tack so no clamping needed
- reversible so I could change things around for artistic appeal at any point in the assembly.
View johnstoneb's profile
johnstoneb
2692 posts in 2048 days
#3 posted 10-14-2016 02:15 PM
x1 Hot Hide Glue
-- Bruce, Boise, ID
