Water based polyurethane over gel stain.
Forum topic by Carloz posted 10-13-2016 01:45 PM 2022 views 0 times favorited 5 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 586 days
10-13-2016 01:45 PM
I just covered a large pine + maple project with General Finishes black gel stain. Flat surfaces two coats, rest is one coat. I am planning to spray General Finishes water based polyurethane on it. Why polyurethane ? since most of the wood is pine I am afraid that it will ding easily and lacquer would crack. Polyurethan should ding together with the wood without cracking. Am I correct ?
Also will water based polyurethane raise grain when applied over oil based gel stain ?
Even if not will applying a coat or two of shellac under polyurethane bring any benefits ?
My main goal is to protect the soft wood from easy scratching/dinging. Look is secondary.
5 replies so far
View Drew's profile
Drew
350 posts in 3095 days
#1 posted 10-14-2016 03:43 PM
Should work fine, but ALWAYS test it out first!
Waterborne products tend to have flexibility and move with dings much better than lacquer.
Yes, grain will raise some.
I wouldn’t bother with shellac unless your test piece doesn’t come out as desired.
Waterborne has good protection, but it’s far from indestructible. I replace restaurant tables every 5 years or so.
I have used every GF waterborne topcoat through the years and would steer you away. I have found better protection with other products. I am a big fan EmTech products from Target Coatings. 8000CV is my go to finish for tables. Milesi seems to be a quality product too.
-- TruCraftFurniture.com
View nkawtg's profile
nkawtg
276 posts in 1246 days
#2 posted 10-14-2016 03:53 PM
One rule of thumb I heard is if you start with oil finish with oil.
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#3 posted 10-14-2016 04:19 PM
Lacquer won’t crack with furniture dings and dents.
Try some sample boards to see how the products interact. Sand the sample board, and finish it just as you intend to with the project. Do one with poly and one with lacquer. I sure prefer lacquer over poly.
Carloz
#4 posted 10-14-2016 05:04 PM
- nkawtg
General Finishes people say that you can start with oil and finish with water provided you give enough time for drying.
Carloz
#5 posted 10-14-2016 05:05 PM
- Drew
How is it better ? Do you mean it resists impacts better or just lasts longer ?
