Choosing a HVLP turbine spray unit
Forum topic by Cooler posted 10-12-2016 01:34 AM 2188 views 0 times favorited 12 replies Add to Favorites Watch
View Cooler's profile
Cooler
299 posts in 1083 days
10-12-2016 01:34 AM
I make mostly smaller items like jewelry boxes, drawer boxes and sometimes a vanity cabinet.
I have to make all new drawer boxes for my kitchen (about 15 drawers) and it would seem that the time to get a spray unit is at hand.
I’ve looked on line for reviews. The Fuji 2903-T70 Mini-Mite 3 PLATINUM – T70 HVLP Spray System @ $517.00 is a reasonable buy.
https://www.amazon.com/Fuji-2903-T70-Mini-Mite-PLATINUM-System/dp/B00D4NPMKI/ref=sr_1_1?ie=UTF8&qid=1476212089&sr=8-1&keywords=The+Fuji+2903-T70+Mini-Mite+3+PLATINUM+-+T70+HVLP+Spray+System
But I’ve been recommended to the Sprayfine A401 4-Stage Turbine HVLP Spray System @ $591.98
https://www.amazon.com/Sprayfine-4-Stage-Turbine-Spray-System/dp/B00GAFDOXO/ref=sr_1_23?ie=UTF8&qid=1476211963&sr=8-23&keywords=hvlp+spray+system
I can find almost nothing written about the Sprayfine unit.
Any suggestions?
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
12 replies so far
View 01ntrain's profile
01ntrain
259 posts in 1310 days
#1 posted 10-12-2016 01:56 AM
Those are professional units, I would think a bit of overkill, perhaps?
A lot of people on this site swear by the Earlex unit, which is less than half the price of those two.
I own the Rockler/HFT HVLP system, that I bought for less than $100. I use it all the time for DIY projects as well as small jobs for customers. It has it’s quirks, but can’t be beat for the price.
View ScottM's profile
ScottM
698 posts in 2386 days
#2 posted 10-12-2016 12:15 PM
Harbor Freight sells that same unit as Rockler so you can see it in person if you need too. I bought the HF one and it does fine for me. It does have its quirks, as said, but I think it’s a good first buy for a sprayer, especially if you don’t see using it constantly. I look at the Fujis every now and then but can’t justify the price for the amount of time and quantity that I would be using it.
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#3 posted 10-12-2016 12:47 PM
I have the Earlex 5500, I love it. It would be more than adequate for your needs.
-- Bondo Gaposis
View GregD's profile
GregD
788 posts in 3376 days
#4 posted 10-12-2016 01:37 PM
Drawer boxes are not always finished, although I much prefer them to be. I have had good luck brushing on a couple of coats of good quality polyurethane on drawer boxes. Unless you are using them to improve your finishing skills I see no advantage to getting fussy about the finish on drawer boxes.
OTOH, drawer fronts, doors, and face frames turn out much better for me if I spray.
Charles Neil has posted a few times that an Earlex 5500 is probably the minimum you want for finishing woodworking projects. “Clear” finishes are easy to spray. Even General Finishes pigmented poly. Heftier sprayers will be able to spray heavier materials such as primers and to some extent interior paints. I have heard that heftier sprayers are able to achieve finer atomization of the finish which can give you a more mirror-like result, but that was from a guy that repairs and/or builds violins.
If you are getting the sprayer for one project, even a big project like a whole kitchen, a low end unit is likely to work out just fine. If you intend to routinely spray finishes then I suspect you’ll be happier over the years with a better unit such as the ones you’ve identified.
-- Greg D.
View CharlesA's profile
CharlesA
3361 posts in 2037 days
#5 posted 10-12-2016 01:48 PM
The Fuji unit sells for $620 on my Amazon, not sure where you can find it for $517. I looked for months. I just bought the earlex 6300 (similar to the 3 stage Fuji) for $449 on sale from Rockler (or through Amazon).
https://www.amazon.com/Earlex-0HV6003PUS-Spray-Sprayer-Pressure/dp/B00JRE163K
View bonesbr549's profile
bonesbr549
1579 posts in 3307 days
#6 posted 10-12-2016 01:53 PM
While I can’t comment on those two models. After you purchase, I’d ditch the siphon cup. buy the 3M pps pressure cup and liners (assuming your gun will have the pressure outlet on the side of the gun).
So much better and when you’re done chuck the cup. Been using it now for years. Can’t imagine spraying any other way. I have the small which is use most of the time and the big one for those big cases. Upside down spraying no problem! Good luck.
http://www.paintboothstuff.com/3m-pps-paint-preparation-system/cups-and-collars?gclid=Cj0KEQjwvve_BRDmg9Kt9ufO15EBEiQAKoc6qr65cK5eBbQjZA0GRm1dfcNDePusWikOqh9mj1XEvtYaApxx8P8HAQ
View Carloz's profile
Carloz
1147 posts in 831 days
#7 posted 10-12-2016 04:41 PM
- CharlesA
So how is the Earlex ? I bough myself a 2 stage version for a little less money, it is still somewhere on the brown truck.
CharlesA
#8 posted 10-12-2016 04:45 PM
I just purchased it and haven’t unboxed it yet.
Carloz
#9 posted 10-12-2016 08:23 PM
While I can t comment on those two models. After you purchase, I d ditch the siphon cup. buy the 3M pps pressure cup and liners (assuming your gun will have the pressure outlet on the side of the gun).
So much better and when you re done chuck the cup. Been using it now for years. Can t imagine spraying any other way. I have the small which is use most of the time and the big one for those big cases. Upside down spraying no problem! Good luck.
- bonesbr549
You must be joking ! That “siphon cup” costs more than half of the whole system. Did you ditch yours ? tell us where.
Besides they are pressure-feed, not siphon cups.
View Drew's profile
Drew
350 posts in 3340 days
#10 posted 10-12-2016 09:19 PM
What products do you plan to spray?
Mini-Mite 3 is a solid system and the T70 is my favorite gun
-- TruCraftFurniture.com
View retfr8flyr's profile
retfr8flyr
386 posts in 1908 days
#11 posted 10-14-2016 04:31 AM
I have the older Earlex 3 stage 6900 model. I have been very happy with it and it has never let me down. The newer versions are supposed to be even better.
-- Earl
View WhoMe's profile
WhoMe
1564 posts in 3483 days
#12 posted 10-14-2016 05:45 AM
I have the basic Rockler/hf unit. It is a great way to get into hvlp without to much money. I like mine a lot and yes, it is not without its quirks. I find it does just fine with thin film finishes. When mine dies I will get the earlex 5500. Much better built and a bit more versatile. But if I had the cash I would get the earlex 6003 setup. It looks like an awesome setup for the money. Having seen it and played around with one straight out of the box but not Used it. Also at the +/-$500 range you start getting into production rated hvlp systems
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
