| Forum topic by stefang | posted 1084 days ago | 1514 views | 0 times favorited | 11 replies | ![]() |
1084 days ago |
I have done a bit or resawing on my 12” bandsaw for a number of years, but I have just purchased a new 18” bandsaw which I plan to use a lot for resawing and sawing my own veneers. Which way do you do it, and why do you like that way best? I have watched some videos and seen both methods used. One obvious advantage to cutting the veneer between the blade and fence (inboard) is that the fence doesn’t need adjusting for each cut, so I am aware of that one already. Any and all opinions are welcome and appreciated. -- Mike, American in Norway |
11 replies so far
#1 posted 1084 days ago |
You nailed the reason I do it between the fence and blade. I cut, then joint the new board face. -- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison |
#2 posted 1084 days ago |
I own a fence called a driftmaster by xxxxxx and it’s pretty spendie for what it is, like most of the tools this company makes I think it’s over priced . It does do veneers. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 1084 days ago |
Dave thanks . I have done the same procedure cutting and planing after each cut for my resawing and that worked very well on my little Delta 12”, so I’m stilling trying to find out if there is any reason whatsoever for outboard cuts. Actually I’m hoping there’s not, because it seems so much simpler to not have to move the fence JimThanks. If the Driftmaster is made by Laguna I saw it being used on a video. The guy in the video was cutting outboard and adjusting the fence each time. I suppose so many turns on the positioning rig handle equals a given depth as he didn’t look at any scale or measure the adjustments. Do you cut on the outboard side with yours? I have a shopmade fence adjuster that I use on my router table, but I see no reason why I couldn’t use it on my bandsaw just as well, providing there is some advantage to cutting on the outboard side. My new saw has a stock high fence too, but I could use a shopmade fence just as well to make it easier to attach my positioner. I do prefer to cut thin strips on my tablesaw outboard, but that’s to make it easier to shove the workpiece through and to prevent burning. I doubt that would be an issue on the bandsaw. I get the impression that you don’t think the driftmaster is particularly useful except for cutting veneers. -- Mike, American in Norway |
#4 posted 1084 days ago |
I have done both without problems… ... the argument for outboard is that when cutting inboard… IE the thinner piece between the blade and the fence is that the pressure of the larger part pushing against the blade may cause it to bind.. and/or drift on the last part of the cut…That has not been the case with my cutting inboard so I continue to do that.. -- Drink twice... and don't bother to cut... @ lazylarrywoodworks.com.au For lovers of all things timber... |
#5 posted 1084 days ago |
When I use it Mike it’s on the inboard side . each turn is 1/32” I try not to say the “L” word, that Company, -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#6 posted 1084 days ago |
Thanks Larry and Jim It looks like I will be cutting inboard. I appreciate the help from all you guys with so much experience. I saw a neat FWW tip for a shopmade fingerboard which is a sort of vertical featherboard but with adjustable ‘fingers’ with feather cuts on the ends of each one. These are mounted horizontally on a vertical board at a an angle to the fence. The four ‘fingers’ slide horiz. to adjust the pressure after each cut to hold the workpiece firmly against the fence. The idea is that the operator can then concentrate on just feeding the workpiece smoothly into the blade at a steady rate without having to press against it at the same time (I need all the help I can get). I haven’t got the BS up and running yet because I’m making some small modifcations to my shop so I don’t have to suck in my stomach to walk around it. I’m hoping to to give it a try sometime tomorrow. I feel like a little kid with a new toy! I’ll do a little blog later just to show it off. -- Mike, American in Norway |
#7 posted 1083 days ago |
Good luck with yoiur new toy Mike. I have a band saw I got last year I still haven’t got set up. Grandkids here for the weekend, so it will be a while before it happens. Not sure if I should work on it or gettting the lathe done ;-)) Sure is a good thing i’m going to live to 100! -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence |
#8 posted 1083 days ago |
Enjoy Mike -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#9 posted 1083 days ago |
stefang, Sincerely, -- woodbutcher north carolina |
#10 posted 1083 days ago |
As a1Jim, I have a driftmaster on my bandsaw. A DVD came with the fence and in the video, one of the selling points is that you cut you veneer between the fence and the blade so that you don’t have to move the fence. I don’t know what type of fence you currently have but the driftmaster is an excellent fence, but is expensive. pkennedy -- P Kennedy Crossville, TN |
#11 posted 1083 days ago |
Thanks Bob, Jim, Ken and P kennedy. I really appreciate all of your replies, help and good wishes. This saw has a great fence for resawing. It is 6 or 7 inches tall (haven’t measure it yet) and really heavy stuff. It’s a shove and tighten type (no micro adjustments). I mounted the few things that had to be mounted, replaced the stock pretend blade with a real blade, adjusted everything that could be adjusted and fired it up. So far I have only resawed a chunk of nicely dimensioned pine 6” wide. It came out perfect (I checked it with digital calipers). The cut didn’t look jointed, but it was very good. So far, so good. My biggest problems so far have been getting the machine into the shop and then making some minor alterations to the shop to make it roomy enough to actually use it. All that’s done now except for some trim. I’m going to take a couple of pics tomorrow to show you what I did, how it looks and a sample resaw for you to judge. Bob I do hope you are going to get your machines up and running soon. I’m really looking forward to getting your take on turning. And of course I’d be glad to help with start-up or other questions you might come up with. Of course with LJ you certainly don’t have to rely on me for help, but it would be fun for me to join in a little. -- Mike, American in Norway |
| Forum | Topics |
Woodworking Skill Share
8848 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
