bandsaw blades bending.
Forum topic by woodkiller posted 07-01-2010 01:55 PM 2311 views 0 times favorited 10 replies Add to Favorites Watch
View woodkiller's profile
woodkiller
103 posts in 2960 days
07-01-2010 01:55 PM
I am a new owner of a Jet 14” bandsaw with a riser block. I have had 2 blades that cut fine on the initial start up but the next day they will track to the back of the wheel and then come off the tire all together. One blade was 3/16” and the other was a 1/4”. The teeth of the blade are towed in, I don’t know if that is from getting too hot or what. The blades are not cheap so I don’t want to mess anymore up. Thanks for the help. Russell
10 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3583 days
#1 posted 07-01-2010 02:08 PM
I don’t use my bandsaw much, but I’d look at the guide bearing adjustment – too far back and it lets the teeth hit the guide blocks. (Upper and lower) Also, the guide assembly should be 1/8 inch or so from the top of the work piece.
-- Joe
View Howie's profile
Howie
2656 posts in 2945 days
#2 posted 07-01-2010 02:31 PM
I would get the book out and go thru the set up procedure step by step and make sure everything is up to spec.
Another problem could be tension.
Trying to cut to tight of a radius.
Just suggestions
-- Life is good.
View richgreer's profile
richgreer
4541 posts in 3096 days
#3 posted 07-01-2010 03:01 PM
You have to start with your wheel alignment. That is what causes the blade to track to the back. Your top wheel is tilted back. Adjust the wheel alignment until the blade is tracking in the middle.
If you are setting your tension based on the markings on the side of the saw you are probably okay in that regard. Normally, those indicators under-tension the blade which is okay for now. It’s rare that anyone over tightens a band saw blade (but I have done it – long story).
Experienced bandsaw users know how to set tension based on the feel or the sound when the pluck the blade. If it is an option, borrow or buy a tension gauge to get the true story and, in doing so, you will know how to set the tension in the future.
Once the blade is tracking in the center with reasonably good tension, set the guide bearings and/or blocks. The bearings and/or blocks should be barely touching (or almost touching) the blade but exerting no pressure on the blade.
View turkva's profile
turkva
29 posts in 3967 days
#4 posted 07-01-2010 03:45 PM
It sounds to me like the wheels are not coplanar. They have to be aligned so the top wheel is directly in line with the lower wheel. You might need to loosen the riser block and twist the upper section in order to bring them into the same plane.
-- Accept Nothing, Challenge Everything
woodkiller
#5 posted 07-01-2010 03:59 PM
When I install the blade I do line the blade so it tracks properly. Then I set the guides just off the blade, and the back guide bearing is just barely touching the blade. The next day the blade tracks to the back of the wheel and when removed the teeth are towed in towards the center of the saw. The 1/2 blade that came with the saw has been fine. I am mainly use the small blades for the bandsaw boxes that I have started to make.
View FWBGBS's profile
FWBGBS
21 posts in 3261 days
#6 posted 07-01-2010 04:49 PM
Wheels not coplanar? I think Turkva hit the nail on the head; at least that’s what I would suspect first. Here are a few bandsaw tune-up guides you might find accommodating.
Smile
-- No sane man will dance ~ Cicero
ajosephg
#7 posted 07-01-2010 05:34 PM
I would think that if the wheels were not coplaner the blade would come off immediately – not the next day.
Tell us more about the teeth being towed in. Not sure what you mean.
-- Joe
woodkiller
#8 posted 07-01-2010 07:06 PM
By being towed in I mean when the blade is removed the blade does not lay flat. If you lay the blade on the floor the flat part on bottom the blade tilts inward toward the center. This has only happens on the thinner blades that I cut curves with. Thanks for all the help.
ajosephg
#9 posted 07-02-2010 05:33 AM
It’s only a guess, but maybe you’re cutting the curves too tight or too fast and stretching the (teeth side?) the blade.
-- Joe
woodkiller
#10 posted 07-02-2010 01:16 PM
I checked last night and the wheels are perfectly coplaner. On this model Jet you don’t even have to take the bed off to check. ajosephg I may be cutting too fast, I don’t think that I am turning too tight though. with a 1/4” blade I am still making a pretty wide sweep. If you look at the bandsaw box I posted Monday that is one that the blade messed up after I completed. Thanks again for the help.
