Switching out a 220 volt motor to 110
Forum topic by Blade66 posted 10-11-2016 01:47 AM 563 views 0 times favorited 11 replies Add to Favorites Watch
View Blade66's profile
Blade66
9 posts in 2935 days
10-11-2016 01:47 AM
I am looking change the motor on my TS from the 2hp 220volt to a 110 volt version if possible. Have moved and onlynplace I have to use the saw doesn’t have 220 volt, only option I see is to switch out the motors since the motor on my CT104 don’t appear to give the option of simply moving wires around on it. Just wondered if anybody has done this switch up and could recommend a good 110 volt motor to look for.
11 replies so far
View bigblockyeti's profile
bigblockyeti
4981 posts in 1625 days
#1 posted 10-11-2016 02:16 AM
Your current motor should have a name plate identifying a frame size on it, sometime as shorthand listed behind “FR”. You’ll need to get one with the same frame for the purpose of mounting it where and how the current motor is. You’ll likely not find a true 2hp motor that will run on 120V, about 1.5hp true power is all you should expect from a reputable motor manufacturer when running on only 120V. You need to keep an eye on the full load amperage (FLA) and service factor amperage (SFA) on the new motor that will be replacing your current one and be sure you have the ampacity with your new service to run it.
4874 posts in 2397 days
#2 posted 10-11-2016 11:07 AM
What he said^^^. Also check motor rotation, most are reversible, some are not. It kind of sucks if it spins the wrong way.
View rwe2156's profile
rwe2156
2796 posts in 1385 days
#3 posted 10-11-2016 12:05 PM
Run a 240V circuit.
View teejk02's profile
teejk02
479 posts in 1029 days
#4 posted 10-11-2016 10:24 PM
Did you pull the cover plate off your existing motor? Many of these are 120/240 volts and it is merely a matter of moving a few wires around…usually explained on the inside motor plate.
View rbm328's profile
rbm328
13 posts in 785 days
#5 posted 10-12-2016 12:50 AM
my grizzly TS is 220/110 20a switchable
View Lee's profile
100 posts in 782 days
#6 posted 10-12-2016 04:33 AM
Ok, assuming the motor is not dual voltage, adding a dedicated 230 volt outlet is much cheaper and a lot easier than replacing the motor
-- Colombia Custom woodworking
View HokieKen's profile
HokieKen
4611 posts in 1043 days
#7 posted 10-12-2016 11:22 AM
- Lee
Run a 240V circuit.
- rwe2156
+1 Assuming your service panel has the space, even if you don’t feel comfortable doing it yourself and have to pay an electrician, it’s not likely to cost much more than what a good 115V motor will run you and you won’t be sacrificing any power or performance by going to a smaller motor. As mentioned above, you’re not going to get a TRUE 2 hp motor that runs on 110. Beware of manufacturers that state their 110 motor outputs more than 1-1.5 hp.
-- Kenny, SW VA, Go Hokies!!!
View GR8HUNTER's profile (online now)
GR8HUNTER
3278 posts in 616 days
#8 posted 10-12-2016 03:25 PM
Run a 240V circuit.
- rwe2156
AGREE
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
Blade66
#9 posted 10-12-2016 05:05 PM
Thanks for the replies, guys, unfortunately running a circuit is not an option for me since, the only place I can use my saw is in the garage at my work after hours of course. It’s set up for automotive repair of the fleet of cabs we service (I’m an auto tech during the day :))
The boss is not open to paying to run a 230V circuit just so I can use my tablesaw.
I think I will just sell the saw, as much as I hate to, for its a nice saw and I got a good deal on it but realistically got no where to use it because of the power issues, not to mention having moved and no longer have my own shop space anymore. Time to kneel in the end zone on this one.
View splintergroup's profile
splintergroup
1872 posts in 1126 days
#10 posted 10-12-2016 05:17 PM
Auto fleet repair?
I’m surprised there is not a 220V source there already (welder, compressor, etc.)
A long extension cord to reach a welder outlet would be cheaper that either a new motor or circuit.
Blade66
#11 posted 10-12-2016 07:19 PM
Auto fleet repair?
I m surprised there is not a 220V source there already (welder, compressor, etc.)
- splintergroup
There is several 220 circuits but are wired directly to the various units.
