Through mortices in thick lumber
Forum topic by kimball posted 07-01-2010 12:04 AM 1202 views 0 times favorited 7 replies Add to Favorites Watch
View kimball's profile
kimball
323 posts in 3205 days
07-01-2010 12:04 AM
Topic tags/keywords: through mortices or mortises joining
Hi,
Over the last couple of years I have developed a fondness for Mission Style furniture. I have struggled to get tight fitting through mortice and tennon joints especially in thick lumber such as legs. I have a morticing machine, a couple of drill presses, a horizontal router table and a vertical router table. But I still have to really “sneak up” on the final size of the mortice (which I make first) otherwise there is tearout or just a sloppy looking hole. Any of you folks have any suggestions or a real good video that I can watch?
Thanks
Kimball
7 replies so far
View David Kirtley's profile
David Kirtley
1286 posts in 2906 days
#1 posted 07-01-2010 12:42 AM
I have been using a multi-tool with a plunge blade. It makes it really easy to get nice crisp sides. It has been a bit of a learning curve and it won’t do small ones but for big thick stuff, it has been great.
View uffitze's profile
uffitze
199 posts in 2863 days
#2 posted 07-01-2010 12:48 AM
I don’t have a fancy video for you, but I can tell you what I do …
I cut ‘em by hand … do your layout on both sides of the workpiece taking care that you’re marking guage’s fence is referencing the same edge, then just cut with a chisel from both sides of the piece.
Depending on the design of the piece that you are making, you can make a wedged tenon which will hide small errors. (Cut your mortise slightly longer on the exit side of the piece, cut a couple of kerfs in the tenon, and drive a small wedge of wood into the kerf. This will effectively make the tenon into a big dovetail that will never come apart.)
View miserybob's profile
miserybob
88 posts in 2952 days
#3 posted 07-01-2010 02:48 AM
Are you trying to go all the way through one side? No matter what method you choose (and it sounds like you have a lot of choices!), you have to come from both sides, otherwise tearout is unavoidable.
View blackcherry's profile
blackcherry
3337 posts in 3731 days
#4 posted 07-01-2010 03:15 AM
I cut my mortise first and then cut my tenon on the band saw a bit oversize and use my shooting jig and a rabbet plane to get the snug fit. It been the best result for me for quit some time now, but there plenty of way’s to skin a cat…BC
View Gary's profile
Gary
9300 posts in 3341 days
#5 posted 07-01-2010 03:28 AM
Maybe, but, the cat ain’t gonna like none of em
116907 posts in 3485 days
#6 posted 07-01-2010 03:45 AM
If you draw out the mortise on both sides and then make a jig and use a router and a rub color to mortise out the back, if not both sides then complete the through mortise and clean up with chisels and a pattern makers file. Then cut the tenon to size for a perfect fit.
kimball
#7 posted 07-01-2010 02:06 PM
I think I see my problem. I have been trying to go through from one side. Never thought about attacking it from both sides.
Whew! It sure is nice having you folks to fall back on. Thanks,
KImball
