Wood Planer
Forum topic by lovey posted 10-10-2016 05:29 PM 515 views 0 times favorited 4 replies Add to Favorites Watch
View lovey's profile
lovey
2 posts in 588 days
10-10-2016 05:29 PM
Topic tags/keywords: wood planer ridgid weathered wood tip trick question
Hi There: I just got a new Ridgid wood planer Model # 4330. After setting everything up, we ran the first board.
At about half way it took out a deep gouge, about 6 inches, and shut down. It seems to be locked up.
The Motor runs but the knives do not engage,and the belt is not turning. The self feed is not working.
There is nothing in the owners manual to address this and unfortunately, there is not a phone number for tech support.
My project is converting an old 2 story home on our ranch in Wyoming, into a Bed & Breakfast, I have collected the wood off of original homestead cabins on the ranch to use to wainscot in the bedrooms.
Since the wood is 100+ years old I take great care to clean and allow it to dry thoroughly before planing.
Anyone out there had a similar problem? It seems there should be a way to reset, but the reset is not doing anything,I am very rural and hoping my husband can do that thing he does to fix things up. He’s currently baffled.
Thanks so much. Cricket
-- Cricketmills1@gmail.com
View MT_Stringer's profile
MT_Stringer
3168 posts in 3225 days
#1 posted 10-10-2016 05:42 PM
Did you hit a hidden nail or something else metallic? Unplug it and check your knives to see if they are damaged.
View MadMark's profile
MadMark
979 posts in 1447 days
#2 posted 10-10-2016 06:04 PM
How thick of a cut were you taking?
Also, did you wax the feed trays?
M
View HokieKen's profile (online now)
HokieKen
4965 posts in 1133 days
#3 posted 10-10-2016 06:46 PM
I’m not familiar with that specific planer. However, it sounds like it may be a sheared key on the belt drive pulley or a busted gear (depending on how the drive train works). You’ll need to pull covers so you can see what drives the belt and trace the system back to see exactly what the motor should be driving that isn’t turning.
-- Kenny, SW VA, Go Hokies!!!
View Bill White's profile
Bill White
4928 posts in 3955 days
#4 posted 10-10-2016 08:45 PM
Sounds like a return trip to Home Depot.
Don’t waste your time or repair. Take it back.
Bill
-- bill@magraphics.us
