Mortising Machine
Forum topic by Andrewst posted 10-10-2016 05:43 AM 733 views 1 time favorited 9 replies Add to Favorites Watch
View Andrewst's profile
Andrewst
13 posts in 751 days
10-10-2016 05:43 AM
Topic tags/keywords: mortising joining tip question
Hello All,
I am in the market for a mortising machine. I am wondering if anyone of you have any tips when looking for one or if you have any recommendations when looking for one. Please send me the brands to go with and maybe ones that have been a problem to other people.
Thanks,
Andrew
-- Andrew, Home Hobbyist, Canada
9 replies so far
View rwe2156's profile
rwe2156
2880 posts in 1443 days
#1 posted 10-10-2016 12:11 PM
I picked up a used Powermatic floor mortiser. Great machine. I wasn’t considering a floor model, but getting this machine for $400 was such a deal I couldn’t pass it up.
You don’t specify, but if you can spring for a floor model, then I highly recommend the PM.
For benchtop models, I know many will disagree, but IMO 1/2 HP is underpowered. I think 3/4 is minimum and 1 best. That eliminated all except the Powermatic 3/4 HP and the Woodtek 1HP model (which I think has been discontinued). I was leaning toward the Woodtek when I discovered the XY table Rikon.
I read mixed reviews on the Rikon but the WC people assured me I could return it if I didn’t like it. I was actually going to my local WC store to buy the Rikon model on sale, when I found the ad for the PM the night.
Bottom line: I would check out the Rikon XY table model.
View GR8HUNTER's profile (online now)
GR8HUNTER
3628 posts in 674 days
#2 posted 10-10-2016 03:27 PM
I find that my drill press set up is fine for me …. since I do not make a lot of furniture ….... you must consider just how much you will use it …..... then you can decide on a model ….....also CL is a good place to start …...... people that bought and hardly used theirs
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
View ChefHDAN's profile
ChefHDAN
1047 posts in 2811 days
#3 posted 10-10-2016 03:36 PM
Yep, you’ve got to decide how much you’ll use it. I keep watching for them on Craig’s list to see if I could get a silly deal for one under $100 because I’ve gotten pretty good with just doing them on the router table. The Domino then threw a whole new wrench into the decision because why buy a single function tool when the Domino can do SO much more & mortises….. But Festool is dammed expensive… Let’s see, cost of tool / number of uses x number of hours to play = I keep using the router… but one day…....
View pintodeluxe's profile
pintodeluxe
5616 posts in 2775 days
#4 posted 10-10-2016 03:38 PM
I have used the Delta benchtop in the past. I made perhaps thousands of mortises with it, and it did produce satisfactory results. However, it requires significant effort to mortise with a 1/2” chisel. Also the hold-down didn’t work very well. As you retract the chisel, the workpiece would lift up or rack, causing the chisel to bind. I broke an inner gear, handle hub, and several locking knobs on the Delta. I repaired them successfully, but at a cost and inconvenience.
I now use a Jet JFM-5 floor model (same castings as the Powermatic but no tilting table) and it is a dream.
Here is my review on the Jet floor model… http://lumberjocks.com/reviews/4377
I think if I was looking at a bench unit today, I would get the Powermatic 701.
The Rikon is tempting because of the X-Y table, however the table is very small and it gets poor reviews.
View CB_Cohick's profile
CB_Cohick
484 posts in 1213 days
#5 posted 10-10-2016 04:43 PM
I have a Delta benchtop mortiser I got from Craig’s List. It works well, but I don’t think I would buy it again. Here’s why. 1) The collar that holds the mortising chisel in place is 5/8” in diameter. There are chisels of that size available (Lee Valley) but there is a much wider selection in 3/4” and from multiple sources. 2) The chuck key is unavailable anywhere as far as I know. When I lose or break the current key, I am in the market for a Jet mortiser probably.
-- Chris - Would work, but I'm too busy reading about woodwork.
View moke's profile
moke
1154 posts in 2738 days
#6 posted 10-10-2016 04:43 PM
Andrew,
+1 with ChefHDAn be sure to check craigslist or ebay. It seems lots of people buy a mortising machinem becasuse they think they need one. Then they discover Kreg jigs, and doweling and it sits….so there are a lot of them out there.
I personally have a jet and like it well…
Mike
-- Mike
View RogerM's profile
RogerM
792 posts in 2361 days
#7 posted 10-10-2016 05:16 PM
I have really enjoyed my General tilting bench-top mortise machine.
http://powertools.publicvm.com/p/Woodworking-Tools/226/compare-products.html
-- Roger M, Aiken, SC
View dschlic1's profile
dschlic1
421 posts in 1931 days
#8 posted 10-10-2016 06:09 PM
Woodsmith Magazine has plans for a DIY mortise that uses a router:
http://www.woodsmithplans.com/plan/router-mortising-machine/
View AandCstyle's profile
AandCstyle
3023 posts in 2219 days
#9 posted 10-10-2016 09:46 PM
Andrew, I have a Jet bench top model that I don’t use because of the poor hold down and I really like the speed and accuracy of cutting mortises with a router. FWIW
-- Art
