Precision Straight Edge
Forum topic by JustLikeJames posted 10-10-2016 12:21 AM 1156 views 0 times favorited 20 replies Add to Favorites Watch
View JustLikeJames's profile
JustLikeJames
173 posts in 1737 days
10-10-2016 12:21 AM
Topic tags/keywords: straight edge precision
I am interested in a precision straight edge for machine setups and reference. I can’t justify the expense of a Starrett brand. Fwiw, I have a Johnson 48” long alum ruler that is so straight I can’t imagine much difference. The problem is it doesn’t stand on edge very well. I happened to find this item on ebay for just $45, guaranteed straight within .005” over the 50” length. Compared to Starrett prices, it seems too good to be true. Has anyone ever use one of these?
Any advice?
20 replies so far
View Aj2's profile
Aj2
1792 posts in 1972 days
#1 posted 10-10-2016 01:09 AM
I tried to follow the link but it just shows shaving stuff.
Alot of woodworkers including me have the lee valley steel straight edges.http://www.leevalley.com/US/wood/page.aspx?p=56676&cat=1,240,45313,56676
See if this link works.
Aj
-- Aj
View DirtyMike's profile
DirtyMike
637 posts in 1076 days
#2 posted 10-10-2016 01:18 AM
Know a buddy at your local machine shop?
View Redoak49's profile
Redoak49
3596 posts in 2163 days
#3 posted 10-10-2016 01:21 AM
I have the Veritas aluminum straight edge and it works well for me. I have used it to set up my jointer and planers.
View AlaskaGuy's profile
AlaskaGuy
4633 posts in 2483 days
#4 posted 10-10-2016 01:29 AM
Aj
- Aj2
Actually there was a Starrett 36 in machinist straight edge mixed in with the shaving stuff. It’s on eBay for 85 bucks
JustLikeJames
#5 posted 10-10-2016 02:33 AM
No, unfortunately.
Aj
- Aj2
JustLikeJames
#6 posted 10-10-2016 02:36 AM
JustLikeJames
#7 posted 10-10-2016 02:39 AM
Sorry about that. The first link was from a pc. I added one that was for mobile devices. Thanks for letting me know.
Aj
- Aj2
Aj
- Aj2
Aj
- Aj2
View dschlic1's profile
dschlic1
442 posts in 2144 days
#8 posted 10-10-2016 06:17 PM
I have used other instruments from Taylor and PEC. Very high quality material. I have not purchased a straight edge from them however. I have purchased a combination square and a machinist precision square. Both are excellent.
View HokieKen's profile
HokieKen
6606 posts in 1313 days
#9 posted 10-10-2016 06:28 PM
Taylor Toolworks is a distributor and doesn’t manufacture any of the stuff they sell. They have great customer service and stand behind what they sell. They state a tolerance on the straightedge so, if it doesn’t meet that spec, I have no doubt they’ll replace it or issue a refund. No experience with any aluminum straightedge but, for occasional use, it should be more than sufficient. However, if you’re going to use it regularly on steel and cast iron, don’t expect it to last forever because eventually it’ll start to wear.
-- Kenny, SW VA, Go Hokies!!!
View diverlloyd's profile
diverlloyd
3180 posts in 2031 days
#10 posted 10-10-2016 06:31 PM
If you like what you have why don’t you just cut a slot in two pieces of wood that the rule will sit in. So the rule will be on its edge and the wood will hold it up edge.
JustLikeJames
#11 posted 10-10-2016 06:41 PM
Thanks, good to hear.
- dschlic1
JustLikeJames
#12 posted 10-10-2016 06:43 PM
Thanks. I would use this for reference only, not frequently, and I’d treat it with kid gloves.
Taylor Toolworks is a distributor and doesn t manufacture any of the stuff they sell. They have great customer service and stand behind what they sell. They state a tolerance on the straightedge so, if it doesn t meet that spec, I have no doubt they ll replace it or issue a refund. No experience with any aluminum straightedge but, for occasional use, it should be more than sufficient. However, if you re going to use it regularly on steel and cast iron, don t expect it to last forever because eventually it ll start to wear.
- HokieKen
JustLikeJames
#13 posted 10-10-2016 06:51 PM
I have used a small spring clamp at each end to stand it up also. That’s how I set up my table saw but I didn’t get it perfect. I was just interested in having a true “master” (so to speak) straight edge that I could really trust for when I get ambitious and try to tune it a little better. Also, I use it all the time and it’s inevitable that I’ll drop it at some point. I’ve been given a couple options here that are all much more affordable than Starrett. I’ve even learned that Empire levels are milled to pretty good precision. Not spec’d as accurate as these other options, but in a pinch it could work.
If you like what you have why don t you just cut a slot in two pieces of wood that the rule will sit in. So the rule will be on its edge and the wood will hold it up edge.
- diverlloyd
HokieKen
#14 posted 10-10-2016 06:58 PM
FWIW, levels are too thick to be used as true straight edges. They can hide areas where light would show through on a narrower surface. Not saying they aren’t good enough for what you may need it for, just something to consider.
JustLikeJames
#15 posted 10-10-2016 07:10 PM
That is a good point. That’s why I don’t use my level like that, because the light doesn’t get under very well. I am surprised at how straight Empire grinds them though.
FWIW, levels are too thick to be used as true straight edges. They can hide areas where light would show through on a narrower surface. Not saying they aren t good enough for what you may need it for, just something to consider.
- HokieKen
