looking to buy a lathe
Forum topic by bluerobbin posted 06-30-2010 01:59 AM 1178 views 0 times favorited 8 replies Add to Favorites Watch
View bluerobbin's profile
4 posts in 2818 days
06-30-2010 01:59 AM
I am a visual artist looking to purchase my first wood lathe. I have recently purchased about 20,000 pieces of birch doweling from a business that closed. The pieces are between 10 and 36 inches long and widths from 1/2 to 3 inches in diameter. I intend to turn this wood into decorative spindles (and possibly paint) for a sculpture project. I am looking at mini jet or delta midi lathes. Could someone give me some guidance, I have a limited budget under 1000.00 with hand tools and would like something that would accept many hours of daily use.
8 replies so far
View Edziu's profile
151 posts in 2981 days
#1 posted 06-30-2010 03:29 AM
When this piece of artwork is done (or pieces) or when the dowel supply runs out, will you not need the lathe any more?
Should this be the case, I would stick with an Excelsior Lathe from Rockler. The lathe itself is $249.99 and the extension, which I believe you would need, is $79.99. This lathe often goes on sale for $249.99 with the bed extension free. Keep your eye out for that. I recommend this lathe because it leaves a lot of room in your budget for lathe tooling. Depending on what you need to do, you can spend more on the tools than the lathe.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3216 days
#2 posted 06-30-2010 03:38 AM
I’m partial to Jet, but there are certainly others in that price range that would serve you well.
You can easily come in under budget including good turning tools
View rsmith71's profile
269 posts in 2972 days
#3 posted 06-30-2010 03:57 AM
Check out this review: I aslo bought this lathe and think it’s possibly the best value for the money at $299. Especially whaen you catch it on sale or use a 20% coupon. Leaves a lot of that $1000 for turning tools and chucks, etc.
-- Robert - Haven Wood Crafts
View trifern's profile
8135 posts in 3697 days
#4 posted 06-30-2010 04:02 AM
I would go with the Jet and get variable speed.
View Bearpie's profile
2601 posts in 2948 days
#5 posted 06-30-2010 05:58 AM
Whatever you get just be sure to get one with variable speed, you may not need it right away but when you do, it is really really worth having! I would not be without one! Trifern above knows this too. I happen to have a Powermatic 3520 and absolutely love it.
Erwin, Jacksonville, FL
-- Erwin, Jacksonville, FL
#6 posted 06-30-2010 03:16 PM
Thanks for all the feedback!
And in response to Edziu – yes it may be a one off project, but I may use the machine for a couple of thousand hours. (My last wood based project (although it was MDF not wood) I used a scroll saw everyday for 6 months working an average of 10 hours a day, replaceable parts on the delta saw wore out but the machine kept on chugging along. )
I want a reliable workhorse, while noise and comfort are things I am considering. You all have convinced me that variable speed is a must.
View richgreer's profile
4541 posts in 3004 days
#7 posted 06-30-2010 06:25 PM
Let me remind you that in addition to the lathe, you will need some good cutting tools and you will need a good system for sharpening them. People often overlook the need for sharpening their tools. Sharp tools are essential for turning.
With respect to cutting tools, you do not need the real expensive stuff but you should avoid the real cheap stuff. Plan on $150 – $200.
With respect to sharpening systems, you really need a slow speed grinder (preferably with 8” wheels) and a sharpening jig. Plan on $225 – $275.
You may also want some additional accessories for the lathe such as a chuck, faceplates, etc..
If you are doing a high volume of work (and with 20,000 pieces of dowel you may) you might want to consider a duplicator accessory. Think ahead on this one. Duplicators are not available for all lathes. Make certain that the lathe you buy can accept a duplicator and that a duplicator is available. I don’t know how much a duplicator costs because I have never had one.
View BigTiny's profile
1676 posts in 2818 days
#8 posted 06-30-2010 08:20 PM
I too would advise getting a variable speed machine. Have you thought of looking for a gently used one? I recently lucked into a 6 foot bed 9 inch throw lathe with several accessories and a basic set of chisels for $60 Cdn.
As for where to put your money, buy the best cutting tools you can afford. It’s lousy to spend half your time resharpening cheap tools.
If you’re doing a lot of repetetive stuff, a duplicator is GREAT and will both increase your output and your accuracy.
Happy turning!
-- The nicer the nice, the higher the price!
