Holdfasts anyone?
Forum topic by DrJosh posted 06-29-2010 11:42 PM 1404 views 0 times favorited 8 replies Add to Favorites Watch
View DrJosh's profile
DrJosh
50 posts in 2888 days
06-29-2010 11:42 PM
I’m trying to plan the design of a new workbench for my shop. I ran across some pictures online of old english joiners benches and I like the simplicity of that style of bench and the size looks like it could be talored to fit whatever space is available in your shop. The pics that I have seen show a bench with no vices but tons of holes for holdfasts. Does anyone have experience with using holdfasts? Pros and cons? From the pics it seems obviously possible to do hand tool (or power tool, I suppose) woodworking without a vise but with holdfasts only. Does anyone have any experience with using only holdfasts or know of anyone that uses holdfasts exclusively.
-- Josh....in Nashville, TN
8 replies so far
View Gofor's profile
Gofor
470 posts in 3782 days
#1 posted 06-30-2010 02:11 AM
I don’t use them a lot because I don’t have any good ones. My only comment is not to go with cheap cast ones, because they will break in half. Forged and hammered ones will be tougher.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View barryvabeach's profile
barryvabeach
159 posts in 3038 days
#2 posted 06-30-2010 02:28 AM
I don’t use them exclusively, but I do use them a bunch. Joel at TWW sells the Grammercy ones, that I bought, and they are great, but I just checked and he is out of stock. http://www.toolsforworkingwood.com/Merchant/merchant.mvc?Screen=PROD&Store_Code=toolshop&Product_Code=MS-HOLDFAST.XX&Category_Code=&Search=holdfast you might want to call to see when they might arrive. The only “trick” is that once you have rough planed your lumber, you should use a scrap of wood ( or leather ) on top of your work when you hit the holdfast so it doesn’t bruise the workpiece.
View David Kirtley's profile
David Kirtley
1286 posts in 2993 days
#3 posted 06-30-2010 03:20 AM
I use both the Grammercy and the cast holdfasts. Love them both. I will normally reach for them first before a vise. They are so quick and easy. I also like a vise for some stuff but quite simply, I would rather work with stuff up on top of my workbench rather than on the side. Even the best of vises don’t hold things that well when beating things with a mallet. End vises are overkill and tend to bow the work if you tighten them too much. Just a bench stop is fine for planing. The only thing that they don’t do quite as well is hold things on edge unless your bench legs are even with the front of your bench or you have a thick skirt on the front.
With a bench designed for it, I could easily see doing without a vise if you were only doing woodworking. I clamp lots of things besides wood in my vise.
View jusfine's profile
jusfine
2422 posts in 2921 days
#4 posted 06-30-2010 03:32 AM
Lee Valley makes a variety, from brass dogs, to holdfasts, all work very well.
Drill the holes in your top where you want them, put in the dogs or holdfasts and you are on your way.
All the Best!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View PurpLev's profile
PurpLev
8535 posts in 3643 days
#5 posted 06-30-2010 03:54 AM
I also use the grammercy holdfasts and they are fantastic! I use them to secure a piece down to the bench for chopping action, they should work just as well for sawing, but for hand planing I use the vise since I can’t have anything on top of the surface to be planed/jointed/smoothed, and can’t have anything in the way of the hand plane (same holds for routing – although it should work find for some routing applications)
bottom line – yes, it can work, but sometimes it’s just easier to have a vise.
View hokieman's profile
hokieman
184 posts in 3749 days
#6 posted 06-30-2010 04:15 AM
I use mine all the time. I have to admit, though, that I can not remember where I bought mine. I’d recommend geteting one if you are going to do a lot of hand work.
View richgreer's profile
richgreer
4541 posts in 3069 days
#7 posted 06-30-2010 05:02 AM
I put a couple of Kreg Klamp plates in my workbench and I have a couple of Kreg hold down klamps. I think the work great. I’ve tried holdfasts and never had much luck with them.
Here is what I am talking about – -
http://www.kregtool.com/Bench-Klamp-System-Prodview.html
The only problem – - saw dust can build up under the slot. The remedy – a shop vac or an air compressor.
View Bill White's profile
Bill White
4928 posts in 3955 days
#8 posted 06-30-2010 08:27 PM
Had my holdfast made by a blacksmith (Mike Rose) at “DollyWood” many years ago. Seemed to be pleased with the request as it was not the same old stuff. I had never used one before. Man, that puppy rocks. Locks down tightly, pops loose with just a tap, and is perfect for work to be clamped from the top of the bench or the front edge.
Bill
-- bill@magraphics.us
