Ridgid R4513 zero clearance insert
Forum topic by WoodWorkJosh posted 10-09-2016 05:17 PM 845 views 1 time favorited 2 replies Add to Favorites Watch
View WoodWorkJosh's profile
WoodWorkJosh
529 posts in 771 days
10-09-2016 05:17 PM
Topic tags/keywords: ridgid insert zero clearance table saw accessories tablesaw
Does anyone know if anyone is selling zero clearance inserts for the Ridgid R4513 table saw. I can’t find them anywhere, and they are hard to make because they are thin and square? Any suggestions would be great.. Thanks
2 replies so far
View thor2015's profile
thor2015
42 posts in 1113 days
#1 posted 10-09-2016 06:09 PM
I would think that a square insert plate would be easier to fabricate than one with rounded ends.
Take off your existing throat plate and look at the mounting surface underneath. My Kobalt table saw has a thin metal plate but it rests on the heads of the height adjustment screws. I can actually put a 1/8” thick plate in the throat opening but I just have to drill countersink holes on the underside for the screw heads to go into.
WoodWorkJosh
#2 posted 10-09-2016 07:34 PM
It looks like you might be right, if I countersink that might work
