do you use cabinet scrapers?
Forum topic by allthunbs posted 06-29-2010 06:31 PM 1035 views 0 times favorited 4 replies Add to Favorites Watch
View allthunbs's profile
allthunbs
25 posts in 2883 days
06-29-2010 06:31 PM
I’ve just got through scraping a poor planing job and wondered if I was the only one left in the world that used cabinet scrapers? How do you create the burr? What are you using to burnish the hook?
View swirt's profile
swirt
2640 posts in 2936 days
#1 posted 06-29-2010 06:46 PM
No there are a lot of people using them. I use them. Here are a couple of sharpening aids I use for finish work
http://www.timberframe-tools.com/tools/sharpening-card-scraper/
If I am using it for removal and don’t care as much about the a polished surface being left behind, I use Todd Clippingers method I found here on LumberJocks
http://lumberjocks.com/toddc/blog/6753
View hObOmOnk's profile
hObOmOnk
1381 posts in 4092 days
#2 posted 06-29-2010 06:47 PM
I’ve been using card scrapers for about 40 years. I even make my own out of used saw blades, especially thin Japanese pull saws. I use a carbide rod burnisher for turning the burr.
This site has a plethora of information on card scraper.
Do a Google search for hundreds of articles and videos on this subject.
-- 温故知新
View chewbuddy13's profile
chewbuddy13
150 posts in 3249 days
#3 posted 06-29-2010 09:20 PM
I use card scrapers all the time, all the cool kids do.
View Gofor's profile
Gofor
470 posts in 3751 days
#4 posted 06-30-2010 02:07 AM
To create the burr, I use a fine mill file to flatten/square the edge. I burnish it with a home-made burnisher made from a diesel engine exhaust valve stem stuck into a wooden handle. The key to the burnisher is that it needs to be smooth and HARD. Use a wee bit of oil on the edge as you stroke the burnisher. (I lube it by rubbing alongside my nose or behind my ear, but wd-40 works, too). I usually lay the card flat and pull the burnisher toward the edge for the first couple strokes. This will draw any remaining burr back to the edge. I then clamp it into a vise edge up, and stroke it across about three to five times for each edge (softer the card, the less number of times), gradually increasing the angle.
I used to follow the initial edge flattening by mill file with standing the card on end on fine wet-dry paper (600 gr) to get a really smooth edge before burnishing. I have found this to be wasted effort for most use. It does produce a smoother edge for the last pre-finish cut especially on hard and burly woods, so I still do that for some projects.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
