Turning brittle wood
« back to Woodturning forum
Forum topic by loiblb posted 10-07-2016 04:31 PM 895 views 0 times favorited 6 replies Add to Favorites Watch
View loiblb's profile
loiblb
143 posts in 1171 days
10-07-2016 04:31 PM
Any tips on turning brittle wood. The ends of my carbonized bamboo take exception to being turned. Are the carbide tools I’m using helping or hurting?
I managed to remove a lot of material with a rasp but at some point will have to turn the ends that chunk off. thought about applying ca glue to stabilize the ends.
Is faster RPM’s better or worst?
View Kirk650's profile
Kirk650
543 posts in 864 days
#1 posted 10-07-2016 05:58 PM
Right or wrong, I’d try higher speed. And for sure I’d have the sharpest tools possible. Carbide might not be the best way to go.
View HokieKen's profile
HokieKen
6153 posts in 1254 days
#2 posted 10-07-2016 06:01 PM
Yea, put the carbide away. It’s great for lasting forever but it just doesn’t take an edge like HSS. Use HSS tools, keep them sharp and crank the speed up.
-- Kenny, SW VA, Go Hokies!!!
View Woodknack's profile
Woodknack
12329 posts in 2496 days
#3 posted 10-07-2016 10:49 PM
Stabilize with hardener or ca glue.
View Leo Van Der Loo's profile
Leo Van Der Loo
45 posts in 874 days
#4 posted 10-10-2016 09:38 PM
Yes use the ca and a skew to get a clean cut
-- Have fun and take care
loiblb
#5 posted 10-13-2016 03:29 PM
I finally completed the carbonized wood but hit a snag on the fossilized wood. It had to be sanded to shape with progressive sanding. That project is on hold for now. CA glue is a great tool in the shop.
View HapHazzard's profile
HapHazzard
116 posts in 984 days
#6 posted 10-18-2016 12:22 PM
I was going to suggest sanding. If you have an oscillating multi-tool or even a small angle grinder you can prop it against the tool rest and turn the work at low speed and sand down the high spots fairly quickly.
-- Unix programmers never die; they just > /dev/null
