Workbench design question.
Forum topic by groland posted 06-29-2010 05:50 AM 1053 views 0 times favorited 1 reply Add to Favorites Watch
View groland's profile
groland
183 posts in 3407 days
06-29-2010 05:50 AM
Hello,
I am building a workbench for making furniture. I am getting close to finishing the base, but now, I’m having second thoughts about my design. I need to make a decision about this before I glue things up.
I decided to make a heavy bench of red oak. End trestles are ca. 3” square stock with through-mortise and tenon joints. I plan to draw-bore and glue these joints, so I expect that’ll be fine. I have a heavy top of laminated ash that’ll be over 2” thick when done. I have a set of stretchers between the trestles at the bottom ca. 2” x 6”.
I am wondering if this will be enough bracing—whether I ought to add two more stretchers at the top? I thought the workbench top, bolted into the trestles, would be adequate to stabilize the whole, would serve as stretchers, but now I am wondering if I bolt that top on solidly enough to serve that purpose, that expansion and contraction of the top may cause problems.
I believe I have seen designs that use a heavy laminated top and dispense with an upper set of stretchers.
What say you?
George
1 reply so far
View David Kirtley's profile
David Kirtley
1286 posts in 2993 days
#1 posted 06-29-2010 04:05 PM
I took the second set of stretchers path. For two more stretchers you add a huge amount of strength. A 2” thick top is not that thick if the bench is long.
You get 3 inch long oak tenons going through 3×3 beams, you are not going to really need to drawbore and glue. It’s not going anywhere. In fact, if I were getting fancy, I would do some tusk tenons and make it where it could possibly be disassembled.
