Make your own dowels
Forum topic by Dick, & Barb Cain posted 03-04-2007 02:37 PM 19026 views 0 times favorited 13 replies Add to Favorites Watch
Dick, & Barb Cain
8693 posts in 4541 days
03-04-2007 02:37 PM
I made a dowel making jig when I made my windsor chairs, but today I found a much simpler way, & you don’t have to make a jig. You can make a more accurate dowel this way also. All you need is a bullnose bit, & your router table. Check this out.http://www.routerworkshop.com/easydl.html
Here’s were I get my bits with free shipping.
13 replies so far
View Obi's profile
Obi
2213 posts in 4479 days
#1 posted 03-04-2007 02:43 PM
I saw this , which isnt as versatile, but easy. I think I’ll order a few bits for the different sizes.
And you forgot to post this site
Dick, & Barb Cain
#2 posted 03-04-2007 02:49 PM
Thanks Obi
I new I forgot something.
View Obi's profile
Obi
#3 posted 03-04-2007 02:54 PM
I was notising the only problem with the router bit is you have to have the exact size of stock. I was looking to make some 1/4” dowels wirhout spending the $169.00 on the thing Karson bought.
Dick, & Barb Cain
#4 posted 03-04-2007 04:42 PM
I think any dowel maker you use you have to resaw to correct size.
View oscorner's profile
oscorner
4563 posts in 4552 days
#5 posted 03-04-2007 04:50 PM
Those are some neat ways of making dowels, but I still stand by my lathe. If I cut stock to 1/16” oversize, it will only take seconds at 1000 rpms to round it. As always, the tool to use depends on the amount of dowel needed and if the cost of puchasing it is more or less that it would take to manufacture it yourselves. Those two are a lot cheaper than a lathe or the $169.00. Sometimes there are too many choices, aren’t there?
-- Jesus is Lord!
Dick, & Barb Cain
#6 posted 03-04-2007 04:56 PM
OS
The problem with the lathe is if you need long dowels, they tend to flex on you.
View scottb's profile
scottb
3648 posts in 4569 days
#7 posted 03-04-2007 05:35 PM
Yep, the two spurtles I made are about 3/8 – 1/2 inch in dia. 12” long, was nervewracking getting them down to that thin needed to use my freehand to prevent flexing. I don’t see myself making anything thinner than that at that length.
-- I am always doing what I cannot do yet, in order to learn how to do it. - Van Gogh -- http://blanchardcreative.etsy.com -- http://snbcreative.wordpress.com/
View Obi's profile
Obi
#8 posted 03-04-2007 06:11 PM
Dont you have to be good at a lathe first of all? At this point Im looking for something that requires no talent. hahahahaha
View Bill's profile
Bill
2579 posts in 4403 days
#9 posted 03-04-2007 06:37 PM
It sounds like the router bits are the way to go for the inexpensive route. The late gives you the opportunity to make almost any size dowel you want, but more skill, time and cost involved. Then there is Obi’s poor man’s lathe that he mentioned in another posting (clamp stock in drill, turn on and sand down).
This is the kind of thing Lumberjocks is for, sharing methods and tools to help each other out. Great topic.
oscorner
#10 posted 03-04-2007 08:00 PM
You are all correct. Flexing of thin stock and being limited to a dowel 36” in length are limiting factors. Personally, I haven’t found the need for a dowel longer than that. If you don’t own a lathe, then don’t buy one to turn dowels, for sure. The router bit setup or Obi’s suggestion would be the way to go. If you don’t own a lathe, router and router table or have the time or money to make your own, then just go to the local box,craft or hardware store and buy it. I’ve even been know to use a pecan or oak branch and a knife to take off the bark and shave it down to fit the hole I drilled instead of making a special trip to buy a dowel (this was done on a turned handle I made to replace a plastic one that had broken on a pot). It worked well and kinda gave it a antique look. So, do what works for you and enjoy your woodworking.
-- Jesus is Lord!
Dick, & Barb Cain
#11 posted 03-04-2007 08:16 PM
Hi
This company, Hill Wood Products has their factory near here. You may have seen their products in stores. I used to get dowels from this companies scrap pile of rejects. They burn all their scrap wood nowadays, but I still have a small supply of them. This company also makes biscuits now. They use the bull-nose method for making dowels, only they use multiple cutters, for mass production.
View Bill's profile
Bill
#12 posted 03-04-2007 08:20 PM
Biscuits would be better than burning the scraps.
Dick, & Barb Cain
#13 posted 03-04-2007 08:25 PM
I don’t think this company wastes anything anymore. They still have to heat their plant, & they have their own kiln.
