right angle join of 1/4th and 1/8th thick pieces? how to?
« back to Joinery forum
Forum topic by gn1weirdness posted 10-05-2016 05:28 PM 1052 views 0 times favorited 16 replies Add to Favorites Watch
View gn1weirdness's profile
gn1weirdness
15 posts in 1248 days
10-05-2016 05:28 PM
So I already know the obvious answer, but since they are different thicknesses and this will be for a box I am curious how I could join them so there would be no gap if that makes sense.
Any advice is appreciated
16 replies so far
View Dark_Lightning's profile
Dark_Lightning
3367 posts in 3345 days
#1 posted 10-05-2016 05:40 PM
Cut the 1/8” piece so that the angle is 30° (sharp) and the 1/4” piece so that the angle is 60° (not so sharp). You can think of it as half of an equilateral triangle, if that helps.
[/Math Teacher]
-- Random Orbital Nailer
View Ted78's profile
Ted78
401 posts in 2236 days
#2 posted 10-05-2016 05:50 PM
You cold also cut the thicker piece in a bird’s mouth shape at 45 to butt up against the 45 on the thinner piece and and at 90 to but up against the side of the thinner piece. Does that make sense? Not easy to cut though. Personally I’d probably just cut them both at 45 all the way across and then rip out a triangular shaped piece to fill in the gap and glue it in.
-- Ted
View Picken5's profile
Picken5
266 posts in 2928 days
#3 posted 10-05-2016 06:03 PM
Can you cut a 1/8” wide dado (about 1/8” deep) near one edge of the 1/4” piece? And then slide the 1/8” piece into the dado. Of course, the side of the 1/8” thk piece won’t be flush with the end of the 1/4” piece, so that may not work for you.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
View splintergroup's profile
splintergroup
2500 posts in 1458 days
#4 posted 10-05-2016 06:33 PM
63.5/26.5 degrees.
I like Ted’s solution better though, the “birds mouth” will give you the end-grain free corner on the outside, a nice “lock miter” for alignment, and a simpler 45 degree cut.
View MrUnix's profile
MrUnix
7106 posts in 2435 days
#5 posted 10-05-2016 07:04 PM
63.5/26.5 degrees.
- splintergroup
Yup… (well, 63.4349/26.5650 degrees :)
If ‘a’ = the width of board A, and ‘b’ = the width of board B:
Miter angle of board A = arctan (a/b)
Miter angle of board B = arctan (b/a)
Dark_Lightning
#6 posted 10-05-2016 07:38 PM
Wups, color me red-faced. Right about the 63.5/26.5 degrees. Next time I finish my coffee.
gn1weirdness
#7 posted 10-06-2016 01:54 PM
You cold also cut the thicker piece in a bird s mouth shape at 45 to butt up against the 45 on the thinner piece and and at 90 to but up against the side of the thinner piece. Does that make sense? Not easy to cut though. Personally I d probably just cut them both at 45 all the way across and then rip out a triangular shaped piece to fill in the gap and glue it in.
- Ted78
I am pretty sure I understand what you are saying, any chance of a visual though?
splintergroup
#8 posted 10-06-2016 02:51 PM
I had tried to find a picture without luck, Ted’s idea is worth considering.
Perhaps a mental image?
Think of your box with 1/8” sides and typical 45 degree miters. Now add a flat board, 1/8” thick to the inside of one of the sides (making a 1/4” board”). That is how the joint would look.
(cheesy ASCII drawing)
View Mosquito's profile
Mosquito
9564 posts in 2528 days
#9 posted 10-06-2016 02:56 PM
splintergroup
#10 posted 10-06-2016 02:58 PM
Well, the ASCII was an epic fail!
(here is a picture that is close, just imagine the piece on the right is 1/4” thick and the piece on the bottom is 1/8”)
gn1weirdness
#11 posted 10-06-2016 03:05 PM
I swear I have seen router bits that can make those cuts, or am I just crazy? Either way huge thanks for the visual, very helpful.
Mosquito
#12 posted 10-06-2016 03:10 PM
- gn1weirdness
There are, yes.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
gn1weirdness
#13 posted 10-06-2016 03:33 PM
- gn1weirdness
There are, yes.
- Mosquito
Care to provide a link? I most likely won’t be using one, but curious either way.
Mosquito
#14 posted 10-06-2016 07:36 PM
gn1weirdness
#15 posted 10-07-2016 04:02 PM
