What's causing this tear out? - Update: It's the arbor or flange
Forum topic by lumberjuniorvarsity posted 10-03-2016 10:44 PM 1256 views 1 time favorited 24 replies Add to Favorites Watch
View lumberjuniorvarsity's profile
lumberjuniorvarsity
77 posts in 920 days
10-03-2016 10:44 PM
Hi Everyone,
On the last two end grain cutting boards I’ve made, I have been getting some tear out while doing my second set of cuts. This has been problematic because the tear out is on the surface that mates to another strip, creating small voids in my joints when I do the final glue-up.
After I noticed it the first time I cleaned the blade, which made my blade look nice but didn’t help with the tear out. So I’m trying to figure out how I can avoid this in the future. I have the Delta 36-725 with an Irwin Marples 50T Combination ATB+R blade. I also get a small amount of burning when making these cuts. The material here was 1 5/8” thick walnut.
I have tried making cuts both by using an Incra miter gauge, and also holding material against the fence. Both techniques resulted in tear out.
So is this due to an underpowered saw? Wrong blade for this application? Problem with alignment? Poor technique? Something else?
Sorry for the poor quality picture. Thanks for any advice!
24 replies so far
View pintodeluxe's profile
pintodeluxe
5705 posts in 2838 days
#1 posted 10-03-2016 11:03 PM
Assuming that’s the bottom of the cut, I wonder if your tablesaw has a zero clearance insert?
A thin kerf blade, or one with less teeth will help with the burning issue.
I use a Freud LU86 thin kerf with good results… http://lumberjocks.com/reviews/7386
View Drew's profile
Drew
350 posts in 3125 days
#2 posted 10-03-2016 11:04 PM
I assume you are crosscutting these with a table saw.
If so use a crosscut blade, not an Irwin combo blade, as well as a nice fresh zero clearance insert! The zero clearance is the most important part! A nice crosscut sled will also help to eliminate tear out.
Burning is an indication that your fence and blade are not parallel, or simply bad technique. If it is burning with a miter gauge it is most likely because your blade isn’t parallel with the miter slot
-- TruCraftFurniture.com
lumberjuniorvarsity
#3 posted 10-03-2016 11:20 PM
Assuming that s the bottom of the cut, I wonder if your tablesaw has a zero clearance insert?
- pintodeluxe
It’s actually the top of the cut. Forgot to mention that…
View DirtyMike's profile
DirtyMike
637 posts in 927 days
#4 posted 10-03-2016 11:30 PM
How much of your blade is sticking up past the cut?
lumberjuniorvarsity
#5 posted 10-03-2016 11:35 PM
- DirtyMike
Not much. Maybe 1/4”.
DirtyMike
#6 posted 10-03-2016 11:55 PM
I have the frued combo and have never had trouble with tear out and my old saw was extremely under powered. I would try raising your blade a little or putting masking tape on your lumber.
View pontic's profile
pontic
591 posts in 634 days
#7 posted 10-04-2016 01:38 AM
Try a scoring line where you are making the cut. This is what I do with thin veneered plywood. I use a utility knife and a straight edge. I usually just do the bottom side.
-- Illigitimii non carburundum sum
View Greg's profile
Greg
330 posts in 2899 days
#8 posted 10-04-2016 02:42 AM
Can you tell when the tearout is happening-Can you see it as it’s happening? This is important when diagnosing the root cause. My guess is that it is the back of the blade, as it is coming up, is scraping against one side which points to an alignment issue. If you have a dial indicator you can place against your fence and touch to the front and then the back to ensure alignment to the blade, that would help. If you don’t have a dial indicator simply use a block of wood or metal as a feeler gauge.
Another issue that it could be his blade wobble. I am not familiar with the exact blade you are using but if you are seeing burns and your regular heavy saw marks on the end grain, it could be wobble. Wobble is caused by a blade that is too thin for the amount of feed speed you put on your workpiece. Slow down your feed speed(not to the point that it will burn), and speed/force consistency is absolutely key here. Try not to stop and start during the cut.
I also agree with the others that you could try putting masking tape over the cut line. Raising the blade a little bit higher might help as well, since the higher you go, the fewer the teeth inside the kerf building up heat from friction. Good luck!
-- You don't have a custom made heirloom fly fishing Net? http://www.Sierra-Nets.com
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#9 posted 10-04-2016 02:52 AM
Correct use of a saw blade - from Freud
lumberjuniorvarsity
#10 posted 10-04-2016 03:04 AM
Thanks for the replies, guys. I’ll double check the alignment, but unless it went out of alignment during the course of regular use I doubt I’ll get it better than when I set it up – not that it was perfect.
I also considered scoring the wood prior to cutting, but I’m doubtful that I wouldn’t just end up with a piece of wood that’s both scored (in the wrong place) and has tear out.
I like the masking tape idea. And the feed rate actually sounds like a likely culprit. Glad to know that it’s not inherently an issue of being underpowered. I really like my saw!
View Aj2's profile
Aj2
1436 posts in 1823 days
#11 posted 10-04-2016 03:13 AM
If you really like making end grain boards.Think about getting a bandsaw.
So much waste with a table saw blade.
Jointer,Planer,bandsaw.Drumsander of belt sander.
That’s all.
And remember it’s a cutting board don’t make it too pretty or nobody will want to use it.
A beautiful board is well worn.
Aj
-- Aj
View Lazyman's profile
Lazyman
2051 posts in 1413 days
#12 posted 10-04-2016 04:54 AM
Does it chip out on both sides or just one side of the blade? I wonder if one of the teeth is out of alignment? Have you tried a different blade? Perhaps the stock blade that came with the saw?
View jdh122's profile
jdh122
1018 posts in 2843 days
#13 posted 10-04-2016 06:19 AM
Usually you expect tearout on the bottom rather than the top on a tablesaw. In that case a zero-clearance insert or sled will help, as will scoring cuts. But these won’t help with your issue.
I think that simply raising the blade might sold your problem.
-- Jeremy, in the Acadian forests
View AlaskaGuy's profile
AlaskaGuy
4205 posts in 2334 days
#14 posted 10-04-2016 08:50 AM
The first thing I’d do is play with your blade height. I have a bunch of saw blades and they all seem to have a “sweet spot? Meaning different blades work best at different heights.
lumberjuniorvarsity
#15 posted 10-04-2016 01:41 PM
- Lazyman
Yeah, it only does that chip out on the left side of the blade, not the right. And not on the bottom, if I remember correctly.
Aj
- Aj2
I would LOVE a bandsaw, and I’m definitely noticing the waste with all those repetitive cuts! In a future post I think I’m going to ask for advice about tool buying in conjunction with a move to AK (from CO). I’m going to sell my big tools, so I’ll be able to adjust what I own.
- jdh122
The first thing I d do is play with your blade height. I have a bunch of saw blades and they all seem to have a “sweet spot? Meaning different blades work best at different heights.
- AlaskaGuy
I like this and masking tape as first measures in solving the problem. Easy enough if it works!
Thanks everyone!
