Bandsaw bookmatching question
Forum topic by Marn64 posted 10-03-2016 10:28 PM 441 views 0 times favorited 4 replies Add to Favorites Watch
View Marn64's profile
Marn64
295 posts in 842 days
10-03-2016 10:28 PM
Topic tags/keywords: question cocobolo bandsaw
So earlier this week I posted about making a Cocobolo topped Gibson Les Paul. Well I found two potential Luthier billets for this project, both have a nice color and nicely defined sapwood and heartwood contrast. A carved top Les Paul needs at least 7/16 of an inch to be done, so the entire billet needs to be at least 1 1/4 inches thick in order to be bookmatched, and the piece I find the most stunning is, you guessed it, 1 1/4 thick on the dot. Would it be possible to do this with an ultra thin resawing blade and minimize the kerf as much as possible or should I just suck it up and settle for the thicker but less attractive piece?
-- Benjamin, Milwaukee
View splintergroup's profile
splintergroup
2155 posts in 1279 days
#1 posted 10-04-2016 03:13 PM
So let me see if I have this right. You would like to resaw a 1-1/4” slab into two 7/16” minimum thickness boards?
How wide is the slab?
With a well set up bandsaw and a good blade, that should be fairly easy.
The way I’d do this is to run the slab through my drum sander or planer to get flat and smooth/tearout free surfaces. This might reduce the slab thickness to below the 1-1/4”. I’d then run the edges through a jointer or tables to define a crisp edge for the book match seam.
On the bandsaw, I’d probably install a 1” or 1-1/4” wide blade and have at it. The blade TPI count would probably be 3-6, depending on the wood and resaw height.
After cutting, back to the planer/DS to flatten and true the rough sides left from the BS blade.
Marn64
#2 posted 10-04-2016 03:38 PM
The way I d do this is to run the slab through my drum sander or planer to get flat and smooth/tearout free surfaces. This might reduce the slab thickness to below the 1-1/4”. I d then run the edges through a jointer or tables to define a crisp edge for the book match seam.
On the bandsaw, I d probably install a 1” or 1-1/4” wide blade and have at it. The blade TPI count would probably be 3-6, depending on the wood and resaw height.
- splintergroup
Thanks for the response,
Yes, my goal is to bookmatch into two 7/16 boards. the board is 9 inches wide by the way.
splintergroup
#3 posted 10-04-2016 07:16 PM
Ok, I’m thinking clearer now 8^)
When I heard “re saw blade” I immediately thought “bandsaw”
You are referring to a table saw blade I assume?.
If so, yes, a thin kerf blade should work fine. A standard 1/8” blade will leave you 1/8” extra per piece (9/16”) in a perfect world, but chances are you will be a few thousandths off center and the board will shift a tiny bit during the cut., but you should still have plenty to spare. A thin kerf blade (3/32”) will give you a tad more margin.
With a high fence and a 10” blade raised (in several passes) to max, you can cut a kerf along each edge, establishing a nice groove with which to finish the cut with a hand saw or a quick pass on a band saw (the kerf lets you use a 1/2” or so BS blade).
Example here
View teejk02's profile
teejk02
481 posts in 1182 days
#4 posted 10-04-2016 09:12 PM
- splintergroup
- Marn64
Gotta love “book match”. My experience says you should square/finish the edges of your blank before you slice it so you get a true 90 degree cut and don’t have to trim anything where the boards will have to come back together.
