table saw problem
Forum topic by Mark posted 10-03-2016 06:25 PM 541 views 0 times favorited 6 replies Add to Favorites Watch
View Mark's profile
Mark
950 posts in 2091 days
10-03-2016 06:25 PM
Morning all. I have a General Int. 10” cabinet saw model # 200 MR. It has developed an issue when I try to lower the blade. The blade will drop maybe an inch (but it is quite jerky as it goes down). After the first inch it gets harder to lower, till it finally jams and stops. Raising the blade just a tad will allow me to drop it further then it jams again. Repeat operation several times and I get it down. Coming from the screw mechanism I’m sure. I’ve ben in there with the compressed air, brushes and silicon spray to no avail. Any thoughts or tips would be great.
Thanks you.
mark
-- Mark
View Druid's profile
Druid
1826 posts in 2911 days
#1 posted 10-03-2016 06:39 PM
Just curious as to how old it is? Have you also inspected the pivot point to see if the shaft and bushing are worn or need cleaning and lubrication? I did have a similar problem on a very “experienced” saw many years ago, and the pivot shaft assembly had worn to the point where there was enough play that debris could get in and cause problems. Just a thought.
-- John, British Columbia, Canada
View MadMark's profile
MadMark
979 posts in 1569 days
#2 posted 10-03-2016 06:42 PM
Have you tightened the height lock?
M
View AandCstyle's profile
AandCstyle
3147 posts in 2373 days
#3 posted 10-03-2016 09:36 PM
Mark, you might call General to see if this is a known issue or if they have any suggestions. Let us know the resolution.
-- Art
View MrUnix's profile
MrUnix
6884 posts in 2315 days
#4 posted 10-03-2016 09:38 PM
Clean and lube – preferably a dry lube or wax (paraffin). Compressed air won’t do it. Solvents will. It doesn’t take much build-up to cause problems exactly as you describe.
PS: You may be to the point where a partial disassembly is required to get to everything – those trunnions and other bits are difficult to reach from below. Taking the table off will help a lot and it’s only 4 bolts.
View Mark's profile
Mark
#5 posted 10-03-2016 10:58 PM
Druid. It’s about 4 yrs old, moderate to light use.
MadMark. Height lock ( I assume you mean the bolt that stops the whole assembly when it reaches the bottom) is tight.
Hey Art. How goes it. That’s not a bad idea. I did call the place where I got it from, but the youngster on the other end had no clue.
MrUnix. I did use a silicon lube but with no joy. I’m thinking’ I’m at that point as you said….Durn!
Thank you for all the feed back gents. Always a pleasure.
-- Mark
MadMark
#6 posted 10-04-2016 01:07 AM
Height lock – center knob in blade crank. They drift.
M
