Best all-in-one budget sharpening system Worksharp 3000 or Something else?
« back to Hand Tools forum
Forum topic by nogeel posted 10-03-2016 03:40 AM 1113 views 0 times favorited 10 replies Add to Favorites Watch
View nogeel's profile
75 posts in 1004 days
10-03-2016 03:40 AM
Topic tags/keywords: jig worksharp 3000 worksharp sharpening plane
I realize that sharpening philosophies are like religion, but I am going to ask this anyways.
I am look for a decent all in one sharpening set up for now. With several shop expenses. My preference would be stones and a grinder. But grinder (at least $100), Waterstones $150 (or combostone set) Diamond Plate for Flattening another $150.
It seems like the Work sharp 3000 could be a compromise ($189) plus eventually the wide blade sharpener ($55). plus cost of sandpaper replacements over time (which makes me nervous). But low mess
Any thoughts on cost for fast efficient to keep chisels, plane irons, and lathe tools razor sharp?
-- Jeff, Tennessee
10 replies so far
View waho6o9's profile
8135 posts in 2512 days
#1 posted 10-03-2016 04:03 AM
View gmc's profile
54 posts in 2091 days
#2 posted 10-03-2016 11:31 AM
I love my WS3000 but it can’t sharpen everything. How ever if you build stumpynubbs ws3000 attachment it comes close. It also shows you how to build the.disk and use rubbing compounds which get you out of buying expensive sandpaper for it.
-- Gary, Central Illinois
View mramseyISU's profile
533 posts in 1480 days
#3 posted 10-03-2016 01:02 PM
I’ve got a worksharp and it’ll do almost everything I need. If you do get one, just get the wide blade attachment out of the gate. I almost exclusively use it to sharpen instead of the underside with the see through disks.
-- Trust me I'm an engineer.
View bbasiaga's profile
1165 posts in 1930 days
#4 posted 10-03-2016 02:28 PM
Any diamond plate is flat enough to flatten waterstones. I bought a 4×10” coarse diamond, and flatten my two other waterstones with that. Works great. $99 for it vs much more for their flattening plate. Add a combo 1k/8k stone for another $80 or so, and you’ve got all the stones you need.
I added a Grizzly tormek clone just recently, as reshaping the blades on stones and sandpaper takes too dang long. And my high speed grinder works just a little too fast. If you buy the grizzly, plan to buy the tormek square edge jig. The Grizzly one with the machine is useless.
#5 posted 10-03-2016 10:26 PM
Those of you who made Stumpy’s gig are you using the polishing compound and MDF discs?
-- Jeff, Tennessee
View Matt's profile
160 posts in 886 days
#6 posted 10-04-2016 01:09 AM
I’ve got the Grizzly version of the Tormek T7/T8 waterstone/strop wheels. It works great, but I did have to purchase a few additional accessories for it. I’ve got the Tormek wheel dressing stone (Changes the 220 wheel to ~1000 and back to 220) the Tormek Truing tool, and the grizzly Accessory kit. I was lucky enough to get the grinder at a 25% off on a sale. With all the options this is outside of your price range, but it works great and is much cheaper than the Tormak option. (Which is outstanding!) The big differences are the wheel speed – the Tormek is 90RPM, the Grizzly is 110RPM, the micro adjuster that isn’t on the Grizzly which makes setting angles easy and the quality of the angle setting guide that is provided by Tormek vs Grizzly which is a piece of plastic.
Grinder –
Accessory kit –
Tormak Truing tool – (Grizzly does not make one)
Tormek Dressing Stone – (There is a cheaper Grizzly option.)
-- My "projects" always look better with beer goggles.
View Dick_Cheney's profile
15 posts in 539 days
#7 posted 10-04-2016 03:54 AM
Tormek, is for suckers more so Worksharp, Be a man, get youself a set of stones, diamond is the least messy, and start sharpening. And please send those expensive sharpening guides to a trash can. I never messed a blade sharpening by hand but once I used a guide I took off more on one side. Took some time to fix.
It takes 2 or 3 minutes to sharpen a plane iron or a chisel. I am scratching my head what is the purpose of $600 stone with a motor. If you own a sharpening business then it might be a different story.
View MustacheMike's profile
261 posts in 2023 days
#8 posted 10-04-2016 10:44 AM
I sent Stumpy a email about this thread and your questions about our jig.
-- You can trust Mike -" because I will never pull your stash!" See my show weekly at
View StumpyNubs's profile
7574 posts in 2735 days
#9 posted 10-04-2016 12:53 PM
The Worksharp is an excellent machine for the price. The only real downside is the cost of their sandpaper and honing films. But you can use 6” disc sander paper from places like harbor freight for the course grits (when you are flattening a back or repairing a bevel) and polishing compounds for the honing. I use 1/2” MDF discs instead of their more expensive glass wheels. The polishing compound goes right on the disc and works really well. And if you build some sort of platform around the machine, you can use an inexpensive plane angle jig to sharpen wide plane irons.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications:
#10 posted 10-04-2016 08:30 PM
MDF is flat enough that there isn’t any issues with sharpening?
BTW, I love your show (and finish making the videos for the book ;) )
-- Jeff, Tennessee
