disc/surface sander motor question
Forum topic by ChrisCarr posted 06-26-2010 05:56 AM 931 views 0 times favorited 3 replies Add to Favorites Watch
View ChrisCarr's profile
ChrisCarr
196 posts in 2926 days
06-26-2010 05:56 AM
I was going to build a disc sander out of an old circular saw universal motor (12 amp) but I need to have a atleast a 10” inch disc spin on it because i need to use it for surface sanding boards. So my question is would it possible to build a surface drum sander using a motor like that? I don’t want to buy an induction motor.
3 replies so far
View Gregn's profile
Gregn
1642 posts in 3010 days
#1 posted 07-03-2010 05:51 AM
Never thought of recycling a circular saw into a sander, but then I used them till they died. I don’t think a disc is what you want to do surface sanding with unless their just small pieces. A drum sander might work if you can find a collar to attach the two together. Don’t see why it would be any different than attaching one to a drill.
View cutmantom's profile
cutmantom
405 posts in 3062 days
#2 posted 07-03-2010 06:02 AM
check the rpm s they might be too high for a sander
ChrisCarr
#3 posted 07-03-2010 05:14 PM
cutmantom: wouldn’t the rpm be fine because people use sanding disks on a table saw and a circular saw runs around that rpm?
