Help filling the gap
Forum topic by becikeja posted 10-02-2016 10:59 PM 424 views 0 times favorited 6 replies Add to Favorites Watch
View becikeja's profile
becikeja
841 posts in 2720 days
10-02-2016 10:59 PM
I have glued up several mahogany boards to make a table. The top has a large carving carved into the top. Unfortunately once I carved over one of the joints it revealed a gap, less than 1/32 but visible. What can I fill this with so it will not be visible? I am going to dye (or maybe stain, have not decided yet) the mahogany to darken it up, so I need something that will hold the color well.
All suggestions, tips and tricks appreciated.
Thanks,
View rwyoung's profile
rwyoung
409 posts in 3378 days
#1 posted 10-03-2016 02:47 PM
Pretty much anything you put in there will take up the dye differently than the wood. Your best bet would be to dye the wood FIRST, then make a fill to match. Then select a compatible topcoat to seal both together. Over time, the colors may shift apart. Could be a short time if lots of UV light present, could be a long time. Just depends on the type of dye you select and the filling material.
-- Don't sweat the petty things and don't pet the sweaty things.
View sras's profile
sras
4749 posts in 3036 days
#2 posted 10-03-2016 02:55 PM
Depending on the specifics using thin shavings of the same wood might work. Fixes the color match problem, but can be tedious…
View bondogaposis's profile
bondogaposis
4609 posts in 2258 days
#3 posted 10-03-2016 03:21 PM
Slip some plane shavings in there from the same board with glue, then incorporate them into the rest of the carving.
-- Bondo Gaposis
View TheGreatJon's profile
TheGreatJon
337 posts in 1140 days
#4 posted 10-03-2016 03:22 PM
^I like the sliver idea. I did it once. It was tedious but it worked well. Press fit the thickest sliver that you can manage and then plane or sand it flush.
Packing it with sawdust from the same wood before applying a finish will get it get it close, but it won’t be a perfect match. You could also go for broke and just fill it with a black epoxy or something similar. Depending on the situation this can make it look intentional and part of the design.
-- This is not the signature line you are looking for.
View pintodeluxe's profile
pintodeluxe
5568 posts in 2720 days
#5 posted 10-03-2016 03:53 PM
Try Bondo’s idea with a wood shaving. If you’re still not satisfied with it, apply some furniture wax after the finish is applied. Choose a wax color similar to the finished color of the project.
View jbay's profile
jbay
2050 posts in 806 days
#6 posted 10-03-2016 04:25 PM
Just use some of that Elmers “ProBond” wood filler from Lowes or Home Depot.
It will take a stain just fine. For a gap that small it’s not worth trying to stick slivers in, it’s going to look the same either way.
If not the wood filler I would do it the way rwyoung suggests, using a colored putty to match the stain, then finish.
I would probably put 1 coat of sealer on, and then put in the color matched putty.
It’s a myth that mixing sawdust from your project with glue will match when your staining. First off once you mix the sawdust with glue it will no longer accept stain and depending on what kind of glue it may color differently, especially if you use tightbond.
Natural finished wood, mixing sawdust with white glue, may be an exception.
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
