Festool Wannabe
Forum topic by Gene Howe posted 1059 days ago 631 views 1 time favorited 4 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
3186 posts in 1595 days
1059 days ago
My old saw guide has served me well, but I’ve always wanted a guide that would eliminate the need to take the work to the table saw for final sizing.
Here are some pictures of my attempt to make a more accurate guide.
I started with a “T” track and “T” bar from Peachtree. The first pic is gauging the “T” track thickness.
Thickness
I routed the 3/4 ply in 3 steps.
Here is setting the router bit to correct hight for the second cut.
Bit
Had to gauge the width, too.
And see how much adjustment was necessary
Ahhh, the 1/8” key way key just fits. I’ll lay the key way gauge between the ply and bring the fence to it. Thereby widening the dado.
Pretty decent fit.
Here is a short length of the “T” bar attached to my trusty old Skil Worm Drive.
Luckily, the holes were already in the shoe. Don’t have any idea why they were there, but I’m glad they were.
1/4-20 X 3/4 bolts, lock washers and wing nuts hold the bar aligned with the blade and tight to the shoe.
This pic shows the “T” bar in the “T” track. Next step is to epoxy the track into the dado and take a test drive. That’ll be after the epoxy arrives. Rural living is great, but it does have some drawbacks. :-)
View PurpLev's profile
PurpLev
7730 posts in 1815 days
#1 posted 1059 days ago
cool post. definitely something worth doing at some point.
86981 posts in 1744 days
#2 posted 1058 days ago
cool Idea well done
View Ingjr's profile
Ingjr
98 posts in 1183 days
#3 posted 1058 days ago
Excellent idea. This is one of those ideas that I always wondered why I didn’t come up with. Thanks for posting.
-- The older I get the faster I was.
Gene Howe
#4 posted 1058 days ago
Thanks for the comments, guys.
It’s in the thinking stage, and for me that’s a long process, but I’m trying to figure a jig to do cross cuts using the same principle. Sort of a fixed in place system to cut various widths larger than the 12” sliding miter will handle.
Any ideas would be welcome.
