Make shift card scraper
Forum topic by Josh posted 06-25-2010 09:08 PM 4356 views 0 times favorited 7 replies Add to Favorites Watch
View Josh's profile
Josh
106 posts in 3257 days
06-25-2010 09:08 PM
Topic tags/keywords: question scraper
What are your thoughts on turning a dry wall putty knife into a card scraper? I’m sure it won’t be awesome quality or what not but think it would work to get by for now?
-- Josh, South Jordan Utah
7 replies so far
View PurpLev's profile
PurpLev
8548 posts in 3883 days
#1 posted 06-25-2010 09:10 PM
too thin. doubt it would work too well, even though a card scraper is thin – it still has enough thickness that you can put an cutting edge on it (the burr).
card scrapers are not expensive, don’t think there’s any reason to cheap out and ‘get by’ with anything else.
View Josh's profile
Josh
#2 posted 06-25-2010 09:11 PM
problem is I have quite a list of things that ‘aren’t too expensive’ and the misses is getting annoyed with it
PurpLev
#3 posted 06-25-2010 09:19 PM
:) well, in that case – it’s worth the try.
flatten and hone the edges, and see if you can either use them as is, or put a burr on it – I’d be curious to see how well it works. depending on the thickness of the knife blade this may or may not work.
some folks are using glass plates as scrapers (cut offs, scraps).
View hObOmOnk's profile
hObOmOnk
1381 posts in 4363 days
#4 posted 06-25-2010 09:34 PM
I’ve been making my own card scrapers from used hand-saw blades, particularly modern Japanese pull saws.
I take the blades to a local metal shop that chops them up to the sizes I want.
I true and dress the edges by draw filing, then I turn a burr.
If you can turn a burr on a putty knife, then it might work. Try it.
I was introduced to card scrapers about 40 years ago.
-- 温故知新
View BOB67CAM's profile
BOB67CAM
269 posts in 3307 days
#5 posted 06-25-2010 09:36 PM
try running thru some manufacturing areas and look for metal dumpsters, find a nice thick small chunk of sheet metal and sharpen that, not as good as the spring steel normally but its cheap, the wife wont mind that so much ;)
-- if you dont have it, build it, especially when its a stupid idea
View muddyboggy's profile
muddyboggy
20 posts in 2174 days
#6 posted 03-01-2013 05:04 AM
Cut an old 7 1/4” saw blade in half, just past the hole, square the ends, remove the teeth and smooth to make a curved back. You can then square the base, polish, burnish and roll the burr. You can also make a curved scraper on the curved edge. Easy and cheap. Tell Momma you spent $7 for a scraper and go buy a six pack.
View DKV's profile
DKV
3940 posts in 2739 days
#7 posted 03-01-2013 06:03 AM
Mud, where did you find this post…and what do you mean lie to momma?
-- This is a Troll Free zone.
