Bandsaw blades
Forum topic by Boris posted 06-25-2010 06:58 PM 1229 views 0 times favorited 14 replies Add to Favorites Watch
View Boris 's profile
Boris
190 posts in 2821 days
06-25-2010 06:58 PM
Ok guys, I get the grizzly 5555x, I need a good blade, any suggestion
thanks
14 replies so far
View blockhead's profile
blockhead
1475 posts in 3214 days
#1 posted 06-25-2010 07:16 PM
Give Suffolk a call and tell them what you have and what you want to do and they’ll set you up with a sweet Timberwolf blade. I just got mine in last week and wished I would have ordered it a long time ago.
-- Brad, Oregon- The things that come to those who wait, may be the things left by those who got there first.
teenagewoodworker
2727 posts in 3674 days
#2 posted 06-25-2010 07:38 PM
depends on what you need. regular blades like the woodslicer, timberwolf, and I’ve had good luck with the Olsen blades, work very well for regular tasks. but if you resaw a lot of figured woods, burls, and special woods I would highly suggest a carbide blade. They are amazing.
View Jack Barnhill's profile
Jack Barnhill
366 posts in 3271 days
#3 posted 06-25-2010 07:40 PM
I ordered my blades from Suffolk last week and got them yesterday. Now I just need my new saw. Here’s a link to a special offer from Suffolk. Buy 3 blades and get 1 free. I think it’s only good if you’re first-time buyer but, check out the details to be sure.
-- Best regards, Jack -- I may not be good, but I'm slow -- www.BarnhillWoodworks.com
Jack Barnhill
#4 posted 06-25-2010 07:42 PM
I’ve heard that the carbide blades are not for saws with wheels smaller than 16”. It flexes them too much and they break prematurely. Just what I’ve heard.
View Wiley's profile
Wiley
71 posts in 2936 days
#5 posted 06-25-2010 08:19 PM
I used to be firmly in the Timberwolf camp, but once I tried a WoodSlicer, I can’t imagine going back. I barely need to sand the surface after resawing.
-- "When you lose the power to laugh, you lose the power to think straight" - Inherit the Wind
Jack Barnhill
#6 posted 06-25-2010 08:40 PM
Correct me if I’m wrong but, doesn’t the WoodSlicer only come in 1 size and 1 tooth configuration intended pretty much for just re-sawing? So if want to cut a tighter radius or thinner material then you would need a different blade?
I plan on giving a WoodSlicer a try once I get my new saw and get into more re-sawing projects. I do hear great things about that blade.
View swirt's profile
swirt
2549 posts in 2877 days
#7 posted 06-25-2010 09:14 PM
Wood slice comes in more than one size, but only 1 tooth config. It is primarily designed for resawing. I have 3/4” woodlsicer on mine and am happy with it for resawing. Pattern cutting … ehhh not so much.
Jack Barnhill
#8 posted 06-26-2010 03:40 AM
I see that now. 1/2” and 3/4”. Thanks for setting me right.
View RichardH's profile
RichardH
295 posts in 2908 days
#9 posted 06-26-2010 05:04 AM
Will have to give woodslicer a try for resawing
Been using timberwolf for a long time cutting bowl blanks, patterns, etc. with very good results. Not greatly impressed with timberwolf for resawing though. It’s definitely adequate, but I’ve been curious if I could find better.
-- "It's supposed to be hard. If it wasn't hard, everyone would do it...It's the hard that makes it great."
View 4thumbs's profile
4thumbs
153 posts in 3052 days
#10 posted 06-26-2010 01:59 PM
In my experience, Timberwolf blades are good for shaping but the Woodslicer can’t be beaten for resawing.
-- 4thumbs in MO
View Seer's profile
Seer
304 posts in 3548 days
#11 posted 06-26-2010 02:39 PM
Carbide blades are good for any saw the teeth are the carbide part and a friend has a few that are great and his is a 14 in saw.
-- www.cabinfevercreations.com
View Seer's profile
Seer
#12 posted 06-26-2010 02:40 PM
The bad thing abouyt carbides and this can be avoided is always use a metal detector on your wood because any metal and $125.00 is down the drain and that is why I stick with my blades unless I am cutting my ironwood.
View lew's profile
lew
11942 posts in 3661 days
#13 posted 06-26-2010 05:32 PM
Try these folks:
http://www.highlandwoodworking.com/bandsaw-blades-accessories.aspx
View John Gray's profile
John Gray
2370 posts in 3791 days
#14 posted 06-27-2010 07:09 PM
I agree with lew and use from Highland the Wood Slicer Resaw Bandsaw Blades they do a fantastic job for me. Again the blade you choose will depend on what you are going to use the saw for. If you are new to bandsaws I recommend this book The Bandsaw Book by Lonnie Bird, it is excellent. http://www.amazon.com/Bandsaw-Book-Lonnie-Bird/dp/1561582891/ref=sr_1_1?ie=UTF8&s=books&qid=1277658424&sr=1-1
