Finish for carved pens?
« back to Woodcarving forum
Forum topic by BakerWorks posted 10-01-2016 12:41 AM 508 views 0 times favorited 1 reply Add to Favorites Watch
View BakerWorks's profile
BakerWorks
4 posts in 1407 days
10-01-2016 12:41 AM
Hi everyone,
I recently started hand carving pens and have really enjoyed the process. I carve down the pen blanks to a round shape, then attach the pieces of the pen kit, then another round of carving to get the shape, and then sanding.
Now the first batch I made was on a bit of a time crunch, so I sanded up to 400 grit, but did not apply a finish. On the next round, I had intended to apply a spray lacquer, but ended up sanding to 800 grit, and liked the feel of the wood, so I skipped the finish again. Now I am thinking about the pens over time and what will happen.
Is it ok to leave them unfinished if they are sanded to a high grit? Is there a typical finish used on carving? The other issue it when to apply the finish. I know that when typically turning a pen on a lathe, the finish can be applied after the shaping is done, but before the pen is assembled. With the method I have been doing, I would need to apply the finish after its all put together which would make it difficult.
Any thoughts or suggestions would be greatly appreciated. Thank you everyone.
1 reply so far
View ClaudeF's profile
ClaudeF
797 posts in 1881 days
#1 posted 10-02-2016 12:20 AM
As with any wood object that is going to be handled a lot, unfinished wood will soak up the oils and dirt from peoples’ hands. On my carvings, I usually use a water-based varnish, diluted 50:50 with water as the final finish. Once it has cured overnight, I buff it with a brown paper bag (lunch bag or grocery bag) to remove any raised grain fibers and dust motes. This restores the satin-smooth finish. I suppose over a period of decades, this method will still allow dirt and oils to be absorbed by the wood, but then, most finishes will…
Claude
-- https://www.etsy.com/shop/ClaudesWoodcarving
