How do I do this?
Forum topic by Kurt posted 09-30-2016 10:11 PM 738 views 1 time favorited 7 replies Add to Favorites Watch
View Kurt's profile
Kurt
12 posts in 884 days
09-30-2016 10:11 PM
I want to make something like this for my brother.
Fairly new to woodworking…
How do I make the cut outs in the bottom piece where the phone is? Use a router table with stop blocks?
Any ideas appreciated
7 replies so far
View gawthrrw's profile
gawthrrw
206 posts in 2322 days
#1 posted 09-30-2016 10:27 PM
I would start with the wood oversized and use a pattern bit with the router and a mdf template. Then you would be able to see what you are doing. Then cut the piece to Final dimension around the routed mortises. Just my 2 cents.
-- Rob, Dallas TX
View BurlyBob's profile
BurlyBob
5150 posts in 2140 days
#2 posted 09-30-2016 11:42 PM
Exactly What Rob said!
View oldnovice's profile
oldnovice
6479 posts in 3243 days
#3 posted 10-01-2016 03:30 AM
Yup, what they said before I got my 2 cents in.
You can use the template with guide bushings to get the basic cut out and follow up with a round over pattern bit or continue to use the guide bushings to get the rounded edges.
View Tootles's profile
Tootles
808 posts in 2377 days
#4 posted 10-02-2016 09:01 AM
To add to what has been said, the back in the picture appears to be laser cut and engraved (Best Daddy Ever), but there are other ways of doing that. What is not clear is whether it is hinged, in which case you will need to work out how to achieve that.
-- I may have lost my marbles, but I still have my love of woodworking
View Kaleb the Swede's profile
Kaleb the Swede
1800 posts in 1844 days
#5 posted 10-02-2016 12:09 PM
Hinges could be barrel hinges i think
-- Just trying to build something beautiful
View dhazelton's profile
dhazelton
2657 posts in 2171 days
#6 posted 10-02-2016 12:38 PM
That box has three layers: a bottom, middle and top. Cut the rectangular holes out of the middle section with a drill and jigsaw, then laminate it to the bottom. Easy peasy.
View GR8HUNTER's profile
GR8HUNTER
3118 posts in 587 days
#7 posted 10-02-2016 12:54 PM
- gawthrrw
DITTO …...your easiest way to do it …... nicest …best
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
